Old 04-09-2014, 05:41 PM   #1
werunbklynn
Drives: White FR$
how do you manually load OpenFashTablet maps
okay so i just bought the OFT and i already copied the stock ecu on my tablet. now the problem is it wont let me autoload the tunes, could anyon eplease explain to me upload the tune manually on the OFT. i also downloaded the OTS map and the open flash manager but im still confused on determining which file belongs to my FRS. please much help appreciated and im anxious to see the results. im located in nyc area if anyone wanna meetup and install it for me
werunbklynn is offline   Reply With Quote
Old 04-09-2014, 06:00 PM   #2
Garrett@Openflash
Garrett@Openflash's Avatar
Drives: S2K AP2
Hello, I would be happy to help! it is rather simple to upload tuned files to your OFT manually. First step is to do the initial read. Plug in via OBD2 and head to the "Tuning" section, select the proper vehicle type then you should be able to click the "Read" function. Follow the ignition prompts carefully and allow the OFT to read your ORIGINAL ROM. Get connected to the latest version of the OpenFlash Manager, you can download the application and the OTS maps from openflashtablet.com. In the upload data section your software type will be displayed in the second column. Remember this type. Next simply click on the folder icon next to the tuned file slot you would like to setup. Select the corresponding software type from the OTS maps pack and the appropriate stage.
An updated video guide will be posted very soon showing screenshots of exactly how to do this if you need further assistance.
Garrett@Openflash is offline   Reply With Quote
Old 04-09-2014, 11:30 PM   #3
werunbklynn
Drives: White FR$
okay i finally loaded the map onto the OTF took awhile but finally finished it.
also another thing i found out is that the Windows 8 error also occurs on Windows Vista...the open flash manager kept giving me an error when uploading data. after i installed the windows 8 patch it fixed my error. maybe you guys should fix the patch and let people know it might apply to Windows Vista too.
last but not least i feel the difference much smoother and fast pickup. A+
Question: How to load OFT tunes manually (first production run ECU) FRSFrank Software Tuning 0 04-07-2014 06:46 PM
Ticking sound, under load norsamerican Issues | Warranty | Recalls / TSB 1 12-19-2013 03:53 PM
Can't load forum with Tapatalk 4? Foobar Site Announcements / Questions / Issues 2 09-29-2013 04:52 PM
When doors are locked manually the car won't start whataboutbob Electronics | Audio | NAV | Infotainment 9 10-14-2012 11:10 AM
Can you manually shift automatic version w/out the paddle shifters? maxeveland Scion FR-S / Toyota 86 GT86 General Forum 31 02-01-2012 11:51 AM
