Old 04-08-2014, 01:21 PM   #1
Trashed675
Trashed675's Avatar
Drives: 2013 Ultramarine FRS
Marker light metal clips....GRRRR
For those of you who have replaced your marker lights or just taken them out for whatever reason, you know that the metal clips are extremely frustrating.
When I was putting in my new winjet headlights I accidentally broke one of the metal clips, does anybody know where to get a replacement? All I could find on ebay was the entire marker assembly, most of which didn't say if they included the clips
PLEASE HELP
Trashed675 is offline   Reply With Quote
Old 04-08-2014, 01:28 PM   #2
Kimsey47
Kimsey47's Avatar
Drives: 2016 STI DGM
Dealer.
Subaru STI :
Old 04-08-2014, 02:03 PM   #3
sshole
Clips are part of the side markers. Dealer probably won't sell just the clips.
sshole is offline   Reply With Quote
Old 04-08-2014, 02:11 PM   #4
Chimera
Drives: FRS
did it just pull out of the slot? A pulls out pretty easy, just slide it back in. I have done this many times.. if it bothers you put a little glue in the slot and put it back.
I know my A tab pulls out almost every time I replace the side markers.
Old 04-08-2014, 02:12 PM   #5
asdf
Loading...████████] 99%
asdf's Avatar
Drives: #0517
the clip snapped? if it just came out, throw it back into the sidemarker with some superglue and pop them back onto the car
asdf is offline   Reply With Quote
Old 04-09-2014, 01:12 PM   #6
Trashed675
Trashed675's Avatar
It popped out before, this time it broke.
Old 04-09-2014, 01:19 PM   #7
Deadspool
Much title. Wow.
Deadspool's Avatar
Drives: 2013 BRZ Sport-Tech
Someone mentioned using a zip tie once upon a time, in place of the clip.
༼ つ ◕_◕ ༽つI PUT A SPELL ON YOU ༼ つ ◕_◕ ༽つ
Deadspool is offline   Reply With Quote
Old 04-09-2014, 03:07 PM   #8
Jive Turkey
the tuna, no crust.
Jive Turkey's Avatar
Drives: 2014 Hachiroku of the year
i have the same issue, the TOP clip on the passenger side fell out and i have no idea where it went, now it just dangled. double sided tape works for a little bit but ultimately it falls out....i really need to get a new clip or find a solution for this.
Jive Turkey is offline   Reply With Quote
Old 04-09-2014, 03:12 PM   #9
ayau
Drives: Some rust bucket
See TSB 07-68-12 for an alternative way to remove the side markers. I've tried it myself and it was a lot easier.
http://www.ft86club.com/forums/showthread.php?t=21868
Old 04-09-2014, 03:25 PM   #10
boonFRS
Drives: 2013 Scion FRS whiteout
Use 3mm tape. I broke mine too a long time ago when I kept fiddling with it. I just tape that sucker on the inside and wrap a piece over it so that it sticks to the front bumper. You can't even see it because it's cover. Still there after 1.5yrs later and a few track days.
boonFRS is offline   Reply With Quote
Drivers side marker clips. feldy Cosmetic Modification (Interior/Exterior/Lighting) 21 05-08-2015 02:43 PM
Anyone have stock side markers to donate to me? One of my metal clips broke. stockysnail Northwest 18 03-26-2014 01:28 AM
stock air box metal clips - found 'em cfordart Engine, Exhaust, Bolt-Ons 2 03-12-2014 11:50 PM
Side marker clips ? PhreshhWun Cosmetic Modification (Interior/Exterior/Lighting) 3 08-29-2013 04:21 PM
New LED marker light MemphisR Cosmetic Modification (Interior/Exterior/Lighting) 69 08-21-2013 09:30 PM
