| DIY (Do-It-Yourself) Guides For all DIYs. |
Drives: 2013 Frs
DIY NARDI install 2013 FR-S
Here is a video we did to try and help out a few others who are interested in installing a similar steering wheel.
[ame="https://www.youtube.com/watch?v=eZ2Yp2DMci4"]FRS NARDI Steering WHEEL DIY Install - YouTube[/ame] Hope this helps out Watch in HD por FAVOR Last edited by lukeskyplayer1; 04-05-2014 at 06:25 PM. Reason: skills |
| The Following User Says Thank You to lukeskyplayer1 For This Useful Post: | Lonewolf (04-05-2014) |
Drives: 2013 whiteout FR-S
What about the airbag light and traction control light that I've read about staying on
Are you 20/20?
Drives: Hopes and dreams
Nice video, nice steering wheel
What's the name of that song at the end?
Drives: 2013 Frs
As far as the Airbag and Traction control light goes my friends states it does not show on his dash
Thanks The song at the end is called Real and True by Future |
| The Following User Says Thank You to lukeskyplayer1 For This Useful Post: | AznKirby (04-05-2014) |
Not what you think
Drives: 718 GTS 4.0
| The Following User Says Thank You to alpine For This Useful Post: | LuxuryVapes (04-07-2014) |
1:29 that's maybe the airbag? I hope you had the battery disconnected before you did that.............
Confusing.......what happened between around 8:08 and 8:15? Looks like there was an adapter being screwed into place and then the steering wheel was held in place and pulled away and there were wires sticking out of the center. Was there another ring screwed onto the adapter and some wires attached to the first adapter? Last edited by White64Goat; 04-06-2014 at 01:31 PM. |
#7 | |
Drives: 2013 Frs
Around 8:00 he's just screwing down the actual NRG quick release that connects to your NRG Hub and then it cuts to the next seen where he is pulling the steering wheel away. The wires sticking out of the middle of that piece are for connecting your steering wheel horn. That is what the inside of the Actual NRG quick release hub looks like without the NARDI steering wheel cap over it. Last edited by lukeskyplayer1; 04-06-2014 at 02:03 PM. |
#8 | |
The Original Super Saiyan
Drives: 2014 SWP BRZ
To each his own, Agree to Disagree
#9 | |
Drives: 2013 Frs
I have a Picture of his dash with the car turned on so you can see all of the lights that are currently on but as far as the turn signals go he tells me that you have to almost make a U-turn for the steering wheel to actually catch and click off the signals but no his Horn does not work. WE did not hook the horn up. We probably will later on down the road for inspection purposes but for now there is no horn. We did this install to mainly see how the Nardi will look with his interior and it seems to be as close as it can to being factory which is what he wanted. |
#10 |
Looks like those traction control and airbag lights are on to me
#11 | |
Drives: 2013 Frs
but like I said we simply made this video for tutorial purposes, were not recommending anybody get a certain hub over another. We just wanted to show people the set up we used |
#12 |
Drives: Asphalt Monogram Fr-s
Are you guys going to make a video on how to fix the lights with resistors and connect the horn?
#13 |
Drives: 2013 Frs
| 2013 FR-S SQ Install | deaddawg | Electronics | Audio | NAV | Infotainment | 23 | 01-23-2014 03:21 AM |
| WTB: Nardi Orido/Taniguchi Wheel | keioffice | Want-To-Buy Requests | 0 | 01-09-2014 06:45 AM |
| Nardi Two Spoke Steering wheel | Joakim3 | Cosmetic Modification (Interior/Exterior/Lighting) | 0 | 12-22-2013 03:59 PM |
| FRS/ NARDI NSX/ Kouki NSX/ FORD GT | Tanuki | FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum | 5 | 10-07-2012 02:26 AM |
| Nardi and Personal Steering wheels from Jordan Innovations! | Jordan Innovations | Interior Parts (Incl. Lighting) | 1 | 07-31-2012 01:59 AM |
