Old 04-01-2014, 05:19 AM   #1
636
636's Avatar
Drives: '23 CWP BRZ
Remove Floor Panels?
I'm trying to run a wire behind the pedals and through the kick panel/door trim, but I don't know how to take it off. Has anyone done this?
636 is offline   Reply With Quote
Old 04-01-2014, 07:35 AM   #2
sshole
Floor panels? Like the metal floor pan underneath the seat? Why would you ever want to do that?
sshole is offline   Reply With Quote
Old 04-01-2014, 07:42 AM   #3
BlueDubbinTDI
BlueDubbinTDI's Avatar
Drives: 2013 FR-S, 2012 MCS
What are you wiring bro?
Old 04-01-2014, 10:36 AM   #4
636
636's Avatar
Drives: '23 CWP BRZ
I guess I worded that wrong, haha. I meant the kick panel! And it's a secret!
Old 04-01-2014, 10:45 AM   #5
sshole
There should be a pop rivet or a plastic nut holding the kick panel in that you need to remove (near the clutch pedal on driver side, figure it out on the passenger side). Pull towards the center of the car and the panel should pop out. If not, then you haven't removed the rocker cover panel - lift that straight up.
Old 04-01-2014, 08:38 PM   #6
MObrz5
Drives: 2014 Satin White Pearl BRZ
[ame]http://youtu.be/bu8f3lB9doI?t=6m30s[/ame]
Refer to "6:30" in this video.
MObrz5 is offline   Reply With Quote
Jdm under panels industrial New England 59 07-03-2014 06:39 AM
JDM Underbody panels Laika Exterior Parts (Aero, Lighting, Etc.) 6 02-05-2013 08:23 PM
Whiteout/ Pearl paint issue: Metal panels not matching plastic/ rubber panels? jbsali Scion FR-S / Toyota 86 GT86 General Forum 20 02-04-2013 10:27 PM
will polishing your car to remove swirls remove opti-coat? bacon_cheese_beer Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 11 10-25-2012 10:41 PM
Possible CF dash trim panels, how to remove stock? jm1681 Cosmetic Modification (Interior/Exterior/Lighting) 1 10-11-2012 01:18 PM
