Old 03-31-2014, 04:29 PM   #1
FRSure
Drives: Toyota
Fender Liner Dilemma
So I'm trying to change my signal bulb and my fogbulb... But I can't in life get the fender liner to open up...
When I try to open it, the top part won't let me open it, the bottom part won't let me open it.. :<
Any tips ? The service manual said only remove these 3 screws.
FRSure is offline   Reply With Quote
Old 03-31-2014, 04:31 PM   #2
FRSHunter
Drives: Asphalt FRS
Removing the screws underneath help a lot. It still will require some force to push the liner out though.
FRSHunter is offline   Reply With Quote
Old 03-31-2014, 04:31 PM   #3
FRSure
Drives: Toyota
There is no screw underneath.. It's flat, I can't turn anything underneath. :<
Old 03-31-2014, 04:45 PM   #4
FRSHunter
Drives: Asphalt FRS
There are like a screw and popclips underneath the car per side
Old 03-31-2014, 05:00 PM   #5
BaeK
BaeK's Avatar
Drives: 2013 Whiteout FRS
Use a flathead screwdriver and slowly pop out the heads. (The middle circular heads)
retrofit
BaeK is offline   Reply With Quote
Old 03-31-2014, 05:13 PM   #6
subiestyle
subiestyle's Avatar
Drives: 2014 Monogram FR-S White MT
that flap where you removed the 3 rivets should flap open. then work your way up and it should slide out.
It does take a bit of force.
subiestyle is offline   Reply With Quote
Old 03-31-2014, 05:18 PM   #7
FRSure
Drives: Toyota
Yep. Got it. Takes a lot of force. I was afraid I was gonna break something..
Old 03-31-2014, 06:17 PM   #8
Jyn
Noob
Jyn's Avatar
Drives: FR-S Mammogram
I should've used your screen name as my license plate...
Jyn is offline   Reply With Quote
Old 03-31-2014, 06:20 PM   #9
husker741
It's a tight fit but with enough force you'll be able to penetrate your way in there. Maybe some lube will help. Be gentle, yet forceful and it should open up real easy for you.
husker741 is offline   Reply With Quote
The Following User Says Thank You to husker741 For This Useful Post:
Chattanooga FR-S (03-31-2014)
Old 03-31-2014, 06:22 PM   #10
FRSure
Drives: Toyota
> I got the liner out.. Took quite a bit of force.. Thought I was gonna break something.
Old 03-31-2014, 08:45 PM   #11
Jyn
Noob
Jyn's Avatar
hahaha nice! I had settled on FRST so can't say I'm too disappointed. Many different meanings :p
WTB: Fender Liner, FRS Asphalt front bumper JackSmiley Want-To-Buy Requests 0 02-28-2014 08:44 PM
WTB: FRONT FENDER LINER mr. slim Want-To-Buy Requests 0 01-06-2014 05:05 PM
Dilemma BRZ vs FRS Gost Scion FR-S / Toyota 86 GT86 General Forum 100 03-24-2013 03:26 PM
Car Dilemma DSoundman Scion FR-S / Toyota 86 GT86 General Forum 46 06-29-2012 08:07 PM
I might have a dilemma... NESW20 Other Vehicles & General Automotive Discussions 6 12-08-2009 09:38 PM
