Old 03-31-2014, 01:38 PM   #1
kylem1853
OFT and innovate supercharger
Does anyone know of or have any base maps for a innovate supercharger on the open flash tablet?
kylem1853 is offline   Reply With Quote
Old 04-11-2014, 01:56 PM   #2
SilverFoxBRZ
BRZ Jockey
Drives: 2013 BRZ LTD 6MT Sterling Silver
Guess not. I've been sniffing around for a starting point too. If I can't get something lined up that I am comfortable with I may ditch the OFT and go with Innovate's supplied tune. My knowledge isn't as strong as I'd want it to be for starting cold on a tune like that.
SilverFoxBRZ is offline   Reply With Quote
The Following User Says Thank You to SilverFoxBRZ For This Useful Post:
leicaboss (04-11-2014)
Old 04-11-2014, 02:00 PM   #3
leicaboss
Coffee Snob
leicaboss's Avatar
Drives: '14 SWP BRZ Limited
I love OFT, but if I go with a kit turbo/SC that isn't either the electric SC or Vortech, it looks like I'll have to ditch it
leicaboss is offline   Reply With Quote
Old 04-11-2014, 02:21 PM   #4
FR-S Matt
You will want Ecutek anyway for the additional features and safety functions it has with boosted applications.
The Following User Says Thank You to FR-S Matt For This Useful Post:
Fast_Freddy (04-11-2014)
Old 04-11-2014, 02:26 PM   #5
Shiv@Openflash
Shiv@Openflash's Avatar
Drives: 2013 FRS
The only safety feature currently missing in the OFT is over boost fuel cut which only applies to turbo (not SC) applications. But I think this may no longer be the case soon. If also argue that having digital realtime gauges and alerts is useful too
The Following 3 Users Say Thank You to Shiv@Openflash For This Useful Post:
carlitosway6891 (04-12-2014), DEK186 (04-12-2014), DustinS (02-04-2015)
Old 04-11-2014, 02:51 PM   #6
continuecrushing
continuecrushing's Avatar
Drives: 2013 Firestorm FRS
more info please!
The Following User Says Thank You to continuecrushing For This Useful Post:
Old 04-11-2014, 03:00 PM   #7
leicaboss
Coffee Snob
leicaboss's Avatar
Shiv, my loyalty remains as I have said before in some other threads. I'm looking forward to seeing what you guys do with Jackson's SC, Innovate SC, and maybe even a turbo kit...
Old 04-11-2014, 03:11 PM   #8
Shiv@Openflash
Drives: 2013 FRS
Originally Posted by Shutter View Post
more info please!
No info to give at this time. But I am actively working on overboost protection in some form. I don't think it's going to be a very daunting task but it will take some time to get it implemented.
The Following 5 Users Say Thank You to Shiv@Openflash For This Useful Post:
bfsnail (04-12-2014), carlitosway6891 (04-12-2014), continuecrushing (04-11-2014), Luckrider (04-12-2014), mad_sb (04-11-2014)
Old 04-12-2014, 12:20 AM   #9
mid_life_crisis
Drives: FR-S 10 #103 AT
Please educate me on this (no sarcasm intended, I'm serious).
Fuel cut as overboost protection just seems wrong to me. You have a turbo pumping massive volumes of air into an engine and abruptly reduce the fuel. Isn't this a recipe for a horrifically lean condition? Wouldn't it make more sense to protect the engine by backing off timing and/or closing the throttle a little until the boost comes back in line?
I'm sure there's a piece of the puzzle I'm missing or don't understand. Can someone explain?
Old 04-12-2014, 01:01 AM   #10
FrsDuke
Fanboy
FrsDuke's Avatar
Drives: 2013 ultramarine frs
If there is zero fuel there is zero boom. Takes one revolution of the engine to evacuate the fuel so if the threshold is set low enough it's a very safe and immediate kill switch. At least that is how I picture it working.
I'm done helping those who won't help themselves.
TL;DR:
-Duke
FrsDuke is offline   Reply With Quote
Old 04-12-2014, 07:17 AM   #11
mid_life_crisis
I had a vision of it cutting off in mid spray. All it takes is one revolution to kiss a rod goodbye. I suppose properly executed fuel cut on a modern car would be done by simply not firing the injector on the next cycle, which would work the way you describe. I was thinking too old fashioned and envisioning literally stopping the supply somehow instead of simply disabling the injector between cycles.
Old 04-12-2014, 08:59 AM   #12
FrsDuke
Fanboy
FrsDuke's Avatar
I could be wrong . I'm just assuming that's how it would/ could be done. They may cut spark first or something too. I'm old school as well so was just kinda reasoning it out. I'm curious to know how exactly it's done too. I've never personally tuned anything more complicated than obd0 and carbs so I'm right there with ya . Just seems the simplest, safest explanation I can think of.
TL;DR:
-Duke
Old 04-12-2014, 01:14 PM   #13
Luckrider
My Other Ride's a Jeep
Luckrider's Avatar
Drives: 2013 BRZ Limited
My understanding is that it stops injector pulses which does mean no fuel for the boom. Then you are just pumping air into the engine and even if you somehow manage to cram 200psi into the cylinders (say 50psi compressed via stroke to 200), it is still low enough for the engine to handle. Note, my pressure numbers were pulled from my ass and could be horrifically low... but it still isn't a problem.
Luckrider is offline   Reply With Quote
Old 02-04-2015, 04:54 PM   #14
SpeedWi
SpeedWi's Avatar
Drives: 2014 BRZ (SOLD)
Sorry to revive an old thread. However, I'm looking to pick up this kit from a member on here and currently have an oft. I would like to keep the OFT and run the kit with a OTS/Base tune until i can drive it down to a tuner. Just looking for any updated info on this combo.
Supercharged 2014 DGM Limited
SpeedWi is offline   Reply With Quote
Innovate Supercharger!!! Titanmotorsports Forced Induction 62 08-24-2014 10:25 PM
Used innovate supercharger cjsporl1996 Want-To-Buy Requests 2 03-29-2014 01:38 PM
FS/ Innovate Supercharger evo4g63 Engine, Exhaust, Bolt-Ons 27 02-24-2014 11:08 AM
FS: Innovate Supercharger kit WITH the innercooler alexisfire02 Engine, Exhaust, Bolt-Ons 29 11-21-2013 10:39 PM
