Drives: 2013 GBS BRZ Limited
What all functions are handled by the main (Engine) ECU?
I am curious.
Is there a list of all functions that are handled by the primary (Engine) ECU? I know that the DI injection has it's own ECU, and I believe that the ABS has one. I know that the TC & VSC need to interact with the Engine ECU to cut throttle to prevent wheel slip, but is the software that governs TC & VSC running on the Engine ECU? Or does the Engine ECU just accept commands over the CAN BUS to cut throttle? If the code that controls VSC & TC is in the Engine ECU ROM, then has anyone found it and identified any parameters? IF it is NOT in the engine ECU, then what controller manages TC & VSC? |
EcuTek and Open Flash both have parameters to control launch control and flat foot shifting, but I don't know if they're directly controlling the VSC/TC, or if it is a secondary level of rev limiting that only works with the primary VSC/TC disabled.
DI mapping is controlled by the main ECU, but I believe the injector driver is a separate board/ecu. If the VSC/TC aren't on the main ECU, I would bet they might be part of the ABS?
#3 | |
service manual is here https://dl.dropboxusercontent.com/u/60477179/BRZ.iso might help |
| summit point main 9-14 -9-15 | subaruferrucci | Tracking / Autocross / HPDE / Drifting | 15 | 09-17-2013 05:48 AM |
| Summit Main 9/14-9/15 | fredk | Mid-Atlantic | 2 | 09-02-2013 11:59 AM |
| Three letter word Search Functions? | Beyer Subaru | Site Announcements / Questions / Issues | 3 | 04-24-2013 03:54 PM |
| Does anyone make the '86' badge but for the main emblem? | Nourdmrolnmt1 | Cosmetic Modification (Interior/Exterior/Lighting) | 5 | 03-25-2013 03:50 AM |
| WTB Main Body ECU | Acree | Interior Parts (Incl. Lighting) | 2 | 03-05-2013 05:31 PM |
