Old 03-27-2014, 11:20 PM   #1
swpbrz
Drives: swp brz limited
sticky leaving first gear
Hi I've had a slight issue start becoming more noticeable.
When I am exciting first gear for second it started like a tiny magnet was holding it in I had to put enough pressure on to pull out. Over the last week its become a very strong snag feeling and getting worse.
I'm not speaking about entering 1st or second. That is also difficult at times but no more than other manuals I've driven. However I have never felt this sickness leaving a gear. It could be related to me practicing rev match down shifting into first at low speeds but it was never anything intense. Any one ever expirience this in any car?
swpbrz is offline   Reply With Quote
Old 03-28-2014, 12:15 AM   #2
humfrz
Does it do it when the transmission is warm ..... or just when it is cold .. ??
You're not getting "lazy leg" are you .. ?? (just not pushing the clutch all the way down when shifting).
humfrz
swpbrz (03-28-2014)
Old 03-28-2014, 06:24 AM   #3
swpbrz
Goes away completely when warm yes. It even makes me giddy it shifts so nicely after driving a while. its just a little worrying because it didn't stick in this way the first few weeks I had it even when cold. I will double check for laziness tomorrow.
Old 03-28-2014, 08:08 AM   #4
DarkSunrise
DarkSunrise's Avatar
My first shift out of 1st is always like this when my car is cold.
2022 BRZ Build
2013 FR-S Build
The Following User Says Thank You to DarkSunrise For This Useful Post:
swpbrz (03-28-2014)
Old 03-28-2014, 10:55 AM   #5
humfrz
Well, swpbrz, more than likely, it's just the nature of the beast.
I'd suggest that when you shift the cold transmission from 1st to 2nd, just pull the shifter "slowly & firmly" into position (with the clutch all the way to the floor).
Remember, you are moving a big ol heavy, cold gear, covered in heavy cold oil, along a cold surface with a relatively short stick. It ain't a toggle switch ....
Back in the day, we didn't seem to have that problem ..... wonder why ....
humfrz
The Following 3 Users Say Thank You to humfrz For This Useful Post:
Basket Case (03-28-2014), flippy (03-28-2014), swpbrz (03-28-2014)
Old 03-28-2014, 09:27 PM   #6
swpbrz
Thank you. I think your probably right. Thanks for the input
The Following User Says Thank You to swpbrz For This Useful Post:
humfrz (03-28-2014)
Leaving the community brzninja BRZ First-Gen (2012+) — General Topics 13 03-10-2014 05:06 AM
Front seat removal only leaving rails in?? OICU812 Cosmetic Modification (Interior/Exterior/Lighting) 0 12-05-2013 01:09 AM
Leaving for vacation for 6 weeks PoRco Scion FR-S / Toyota 86 GT86 General Forum 36 04-24-2013 12:33 PM
Leaving from Philadelphia on April 6th? BRZ_Lawyer NY / NJ / CT / PA 48 04-07-2013 09:54 AM
