Northern California NorCal
Old 03-27-2014, 12:00 PM   #1
leicaboss
Coffee Snob
leicaboss's Avatar
Drives: '14 SWP BRZ Limited
Thumbs up Headed to "The Shop" later!
Friends,
I finally got around to getting my Swift Springs and SPC Rear Control Arms + Front Camber Bolts installed. Totally expected my alignment to be off, but this time it was exceptionally bad to the point where it frequently triggers my VSC to kick in and it'll start braking for me in low speed turns. Car is horribly "floaty" and unstable right now, so alignment is happening today @ The Shop, in San Bruno.
I'm looking for handling that's at least as tight as it was stock (BRZ) but can take on the twisty canyon roads with greater confidence than before. I believe my SPC front camber gives me (1.75 +/-) of camber, and the rear is (2.00 +/-). I realize it's not too much to work with... though correct me if those SPC specs are wrong.
  • Swift Springs BRZ Spec; lowered 1" [Front: 3.8/kg - Rear: 4.5/kg]
  • Most of my driving will be on the highway (commuting)
  • Spirited weekend driving up in the "twisties"
  • Occasional track and AutoX usage (May 9th @ Thunderhill HPDE, for example)
  • Seeking handling that is a bit more tame - noob friendly!
Anyway, I appreciate any advice you can provide on a somewhat "all-around" alignment setting given my options. I would appreciate input on how to deal with alignment guys too, to make sure I get what I want.
Many thanks in advance,
David
PS - Taggin' @MyRx @PMok @overlookedx
leicaboss is offline   Reply With Quote
Old 03-27-2014, 12:13 PM   #2
BlaineWasHere
Grip>Drift
BlaineWasHere's Avatar
Drives: FRS
I can't believe your alignment was that far off after installing those parts.
Old 03-27-2014, 12:38 PM   #3
The Racers Line
The Racers Line's Avatar
Drives: FRS, Supra, Colorado D, GLC63
Originally Posted by leicaboss View Post
Friends,
David
It sounds like your rear toe got horribly misaligned. It can cause the car to become very very twitchy and make it very easy to kick the back end out, which is what it sounds like your car thinks is happening. I've installed this same/similar set up on a few different cars with no issue, so this is pretty surprising.
The Racers Line is offline   Reply With Quote
Old 03-27-2014, 12:51 PM   #4
PMok
Codename: Stitch
PMok's Avatar
Generally speaking, you will want to max out the negative camber on the fronts. As much as -2.0 if you can.
And about the same on the rears, aim for -2.
Zero toe in the front, and only a tiny bit of toe in at the rear.
My caveat is that I do very little highway driving, mostly twisties and track.
Old 03-27-2014, 12:55 PM   #5
B2FiNiTY
JDM JUNKY
B2FiNiTY's Avatar
Drives: NSX
Post up a review how it goes.
B2FiNiTY is offline   Reply With Quote
Old 03-27-2014, 01:10 PM   #6
leicaboss
Coffee Snob
leicaboss's Avatar
Tell me about it, try driving in the rain with VSC kicking in, eager to pull you into a wall... Just got to work, was driving with the hazards on the whole time doing 40 max.
Old 03-27-2014, 01:26 PM   #7
overlookedx
overlookedx's Avatar
Drives: 2015 WRB Limited
What he said ^
Try to get as close to -2.0 up front as you can. That is, until you get wider wheels and you have to worry about the tire rubbing the spring perch, but that's a whole other issue.
Superfast Jellyfish
overlookedx is offline   Reply With Quote
Old 03-27-2014, 02:55 PM   #8
MyRx
MyRx's Avatar
Similarly, the SPC camber bolts may only get -1.75 but be more concerned with equal camber rather than "maxed out" camber. The bolts plus your suspensions may not be equal. If this is a proficient shop, they'll know to equalize it rather than letting the customer say "max out".
As for the rears, agree, install may have gone wrong. Get the install checked then recheck it again before dialing it in. The rest people have already mentioned. Good luck.
Old 03-27-2014, 03:01 PM   #9
leicaboss
Coffee Snob
leicaboss's Avatar
Thanks Jessie, the install definitely was done properly! Joey and Ben from "Joey's" in South SF double checked and Matt from The Shop happened to be there (w/ his LS RX7, no less) and he also took a look as well. One thing I forgot to mention is that the toe bushing wasn't installed yet. Matt said he'll see if we need to install it today if we can't get toe to where we want it.
I'll try to achieve maximum negative camber in the front, but making sure it can be done so equally.
Thanks again everyone. I think eventually when I upgrade my wheels, I'll go for a better solution (Raceseng caster/camber plates + Racer X upper control arms)
Old 03-27-2014, 06:39 PM   #10
BlaineWasHere
Grip>Drift
Drives: FRS
Camber being way off wouldn't do this. You have something seriously fucked up in the caster or toe or something for the system to measure such different rotations in the tires from left to right. I lowered my car 2" on coils and it drove just fine for about a week without alignment.
Also why did you spend so much money on arms and stuff vs. just getting coils?!? That baffles me.
Old 03-27-2014, 06:51 PM   #11
The Racers Line
This is just my observation from installing this stuff for people but:
Springs: $300ish
SPC LCA: $200ish
SPC Camber bolts: $20
$520ish + install is maybe $7-$800 vs. decent coil over $1500+ and the average person doesn't know how to properly adjust or use the adjustability of the coil overs.
Again, just my .02
Old 03-27-2014, 07:34 PM   #12
leicaboss
Coffee Snob
leicaboss's Avatar
I paid probably 600 total for new parts and install. I considered coils and almost bought V3s but I prefer the ease of springs.
It turns out the toe was completely screwed up in the rear! At The Shop now and they are doing a great job.
Old 03-28-2014, 03:10 AM   #13
BlaineWasHere
Grip>Drift
Drives: FRS
Springs: $300ish
SPC LCA: $200ish
Again, just my .02
Yeah, good points. After getting springs then coils on my last car I just went straight to coils this time because I knew I'd buy them eventually anyway. I've got almost 50K miles on my V3s now and they still ride great.
Old 03-28-2014, 03:14 AM   #14
leicaboss
Coffee Snob
leicaboss's Avatar
Blaine, I'll post the pic of the before alignment specs... the toe was -1.5 Degrees on each rear wheel... LOL not point something.
Needed opinions: Does debadging "Subaru" and "BRZ" cheapen the car? davidchoi Cosmetic Modification (Interior/Exterior/Lighting) 49 11-22-2014 10:17 PM
"Clicking" or "knocking" caused by rear seat pull down lever. husker741 Issues | Warranty | Recalls / TSB 6 11-27-2013 02:30 PM
"My Dealer told me {insert dumb idea}" (was "Toyota/Subary Partnership Cancelled?") levifig BRZ First-Gen (2012+) — General Topics 48 08-09-2013 06:34 PM
Which Markets have "GT86" and "Toyota" badges on trunk? Tanuki Scion FR-S / Toyota 86 GT86 General Forum 20 02-10-2013 05:23 PM
Anyone else try running "square" tires on "staggered" wheels? hamlet Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 21 12-19-2012 12:59 PM
