Old 03-20-2014, 05:14 PM   #1
cjsporl1996
Drives: WRB BRZ, Monte Carlo SS
Vortech kit question
1.) I can't figure out where the hood prop relocation bracket goes. Right now I just have it sitting in the engine bay with electrical tape holding It down.
2.) I have the original kit and the windshield washer fluid tank does not seem to fit with the brz limited HID housing. I just left it off but if anyone has any suggestions I would appreciate it.
Thank You,
Cjsporl
cjsporl1996 is offline
Old 03-20-2014, 05:20 PM   #2
AZFA20
Automotive Connoisseur
AZFA20's Avatar
Drives: too many cars
Thank You,
Cjsporl
1) Page 16 shows you where it goes. You need to drill your own holes.
http://www.vortechsuperchargers.com/images/97.pdf
2) Pictures of what you are having clearance issues with would help. Should be pretty straight forward.
LSx Powered 86/ASE Master Certified Automotive Technician
AZFA20 is offline
Old 03-21-2014, 03:06 AM   #3
HRTROB
HRTROB's Avatar
Drives: Toyota 86
I suggest just getting hood dampers so you don't have to drill new holes for the hood prop relocation bracket. The Grimmspeed ones are the best ones I've seen. They have the biggest angle and slow down just before they reach full extension.
I can't answer your second question because I have an 86 but mine has factory HIDs and I was able to get the filler neck to fit. It was tight but it went in eventually. Maybe the 86 headlights even with factory HIDs has more clearance since I did not have to remove the passenger side headlight to fit the post-intercooler pipe
HRTROB is offline
Old 03-21-2014, 08:02 AM   #4
kiichiro
corolla specs/GTR looks
Drives: ooh oooh pretty tail lights
Instructions are clear, re read
SOLD THEM BOTH
Hers: 2007 987S
Mine: 2012 991S
That was fun, thanks Hachi
kiichiro is offline
vortech
Vortech SC question Cal3000 Forced Induction 13 08-01-2015 01:26 AM
Question for the the 2014 Brz Nav Owners (BT Question) jbsali Electronics | Audio | NAV | Infotainment 3 07-16-2014 11:41 AM
Vortech question for those that have it Frs32907 Forced Induction 16 02-06-2014 03:17 PM
Vortech e85 question and help ft86me Forced Induction 20 06-09-2013 09:55 PM
BEspoke question and rattle question bdanisi Electronics | Audio | NAV | Infotainment 2 01-30-2013 02:11 PM
