Old 03-19-2014, 05:06 PM   #1
AZFA20
Automotive Connoisseur
AZFA20's Avatar
Drives: too many cars
What are you targeting (AFR/E85)
Basically what the title says. I am just curious what everyone is trying to target on E85 in regard to AFR @ WOT. I know a lot of guys are in the 60-70% range right now but on average what are you trying to target. I personally add about 1 point of AFR across the board when measuring with a gasoline calibrated wideband. You can reference lamda too doesn't matter to me. Just want to see if what I try to target is in line with the consensus here on this platform.
LSx Powered 86/ASE Master Certified Automotive Technician
AZFA20 is offline   Reply With Quote
Old 03-24-2014, 03:40 PM   #2
gonzo
Drives: frs
On the OFT logged AFR you want lower 12s
gonzo is offline   Reply With Quote
Old 03-24-2014, 04:02 PM   #3
mad_sb
Drives: 2013 Asphalt FR-S
I found it did not make much difference power wise so long as your in the 12's gasoline scale. I saw no change in power from 12.4 up to 13. I shoot for 12.5 - 12.8.
Get your afr flat, tune timing for mbt, change afr tune for mbt again and see if it changes power..... You really need to be on a dyno to tune E85, you can easily go past MBT before it knocks.
Ohh, and this is NA... Have not done a boosted corn tune yet.
Old 03-24-2014, 04:54 PM   #4
Luckrider
My Other Ride's a Jeep
Luckrider's Avatar
Drives: 2013 BRZ Limited
My e85 tune runs high 11s at WOT.
http://www.datazap.me/u/luckrider/e8...om=19199-19645
Luckrider is offline   Reply With Quote
Old 03-28-2014, 01:15 AM   #5
DeliciousTuning
PhoneFlash by EcuTeK
DeliciousTuning's Avatar
Though it may not have much impact in power, it will have an impact on response. Every little bit counts, when you are trying to extract every last lbit out of a tune, track or not.
Cheers,
William Knose
Old 10-28-2014, 12:39 PM   #6
diodelphi
diodelphi's Avatar
Drives: 86
Is lambda=0.86 best for E100?
diodelphi is offline   Reply With Quote
Old 10-28-2014, 01:35 PM   #7
DeliciousTuning
Depends on the vehicle, applications (FI of NA), and so much more.
Cheers,
William Knose
Old 10-28-2014, 02:15 PM   #8
diodelphi
diodelphi's Avatar
Drives: 86
Cheers,
William Knose
for NA and for average of stock cars?
Old 10-29-2014, 08:01 AM   #9
ZZT86
ZZT86's Avatar
Drives: BR86
Originally Posted by Luckrider View Post
Same here - high 11's - low 12's
ZZT86 is offline   Reply With Quote
Old 10-29-2014, 02:01 PM   #10
aagun
Drives: 86
tuners use lambda for E85 and anther type of fuel
aagun is offline   Reply With Quote
Old 10-29-2014, 02:13 PM   #11
Jolaessss
Jolaessss's Avatar
Drives: SWP FR-S
@ck-GT86
Jolaessss is offline   Reply With Quote
