Old 03-09-2014, 09:21 AM   #1
Xero-Limit
Xero-Limit's Avatar
Drives: JDL Turbo FRS, 335SC BRZ (ret)
Exclamation Front wideband accuracy
Just an FYI for you self-tuners out there.
Our initial base maps were done with a wideband in the tailpipe, and generally we see the stock sensor pegged at 11 while our wideband indicates 12-11 or so. This is with expanded scaling using hypothetical numbers. Stock mapping is good only for 12.17 at the richest end.
So lately we took a few cars on the dyno that have less traditional maps. Innovate with small pulley e85, NA but with the 3" MAF, and a few remote folks utilizing the new rear o2 functionality of ProECU. This way we can directly see the AFRs imported into the datalogs. Results?
Well, lets just say this. We won't remote tune your FI FT86 unless it is equipped with a proper wideband or you're willing to eat the motor, or it is 100% stock and similar to the OTS mapping. We're seeing pegged rich stock meters while widebands are showing 13. Last year we might see this a handful of times on local cars, but we'd figure it's post cat or just an unusual one. But now we're having folks put these into the rear o2 port on non-catted setups, and we see the same things. Dyno numbers confirm that we lose power being too lean in those cases.
If you have experience with this please post so we can get a better idea of how off they really are. But we're not going to use the stock wideband for anything except NA setups. We may even do a rental wideband you can clip into the rear harness from now on.
Xero-Limit is offline
Old 03-09-2014, 09:45 AM   #2
Victor Draken
Drives: Toyota Gt86
any good and easy wideband setup you suggest for N/A users.
Victor Draken is offline
Old 03-09-2014, 09:47 AM   #3
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
Originally Posted by Victor Draken View Post
any good and easy wideband setup you suggest?
AEM Failsafe if you are boosted is such a no brainer.
Sportsguy83 is offline
Old 03-09-2014, 09:58 AM   #4
Victor Draken
Drives: Toyota Gt86
for N/A instead?
Old 03-09-2014, 10:01 AM   #5
Sportsguy83
Drives: Limited BRZ
for N/A instead?
Best bet is to look for a good brand aftermarket wideband that has an analog 0-5V output. That way you can hook up your regular in car gauge and have an additional output to connect to the rear O2.
http://www.ft86club.com/forums/showthread.php?t=57902
Old 03-09-2014, 10:03 AM   #6
Sportsguy83
Drives: Limited BRZ
In the next few days I'll log OEM AFR and aftermarket wideband to see how different they are.
Old 03-09-2014, 10:04 AM   #7
Xero-Limit
Xero-Limit's Avatar
Innovate, zeitronix, or aem. Just pick one with a 0-5v aux out. No need for failsafe with NA
Old 03-09-2014, 10:13 AM   #8
arghx7
Drives: car
This is always a hot button topic. I see widebands, any wideband really, as just another tool. This issue of "accuracy" is even more complicated than most people realize. The reasons are: backpressure issue, engine-out AFR vs exhaust stream AFR, and transient effects.
I've done some informal studies on this issue using lab data. I compared a Bosch LSU 4.9, a Denso Plus 5.1 limiting-current type wideband (similar to what's the front sensor on the FA20), and an emissions bench in a steady state. This particular engine was an n/a, and the data was running a series of steady-state points for a WOT run. Basic result: they were all within about 0.3:1 in most areas, but yes the Denso seemed to deviate a little at the richest AFR's. That's steady-state, lab conditions, enriched operation, no scavenging to speak of.
There are backpressure compensation curves to keep in consideration. AEM now offers a wideband with a backpressure sensor to use, which corrects the value based on the characteristic curve provided by Bosch. That's assuming you don't burn up the backpressure sensor.
Now here's where things get nuts: on a boosted engine, especially with a lot of scavenging. The wideband doesn't directly tell you what's going on in the cylinder. You can have a wideband read lean at the tailpipe, in the midpipe or wherever. But when you start looking at the fuel flow meters, the airflow meters, the emissions analyzer CO2%, O2%, and CO%, things get pretty tricky.
When you have overlap (especially with boost), fresh air gets thrown out the exhaust valve and is never trapped in the cylinder. It mixes with the CO and other gases. So literally the AFR changes as the gases are passing through the exhaust pipe. You can only see that with an emissions bench in a lab.
In an actual vehicle it gets tricky because those Denso A/F sensors are actually corrected by the rear o2 sensor located behind the cat. It basically uses the rear o2 sensor and an oxygen storage capacity model of the catalyst to compare what the front o2 sensor is reading and what it should read, based on the response curve of the rear o2.
All these complicated effects are why I don't get too caught up in which one is right and which one is "wrong." I do have more faith in the Denso sensors than a lot of people do though.
See attachments with technical specs on Bosch wideband sensors, and an earlier Denso limiting-current type.
File Type: pdf Technical Product Information LSU4.2.pdf (209.7 KB, 425 views)
File Type: pdf Technical Product Information LSU4.9.pdf (371.5 KB, 510 views)
arghx7 is offline
Old 03-09-2014, 10:13 AM   #9
Victor Draken
Drives: Toyota Gt86
How does it apply to ppl that haven't EcuTek and use other software for logging?
I mean... can I just change the OEM Wideband with an aftermarket one that is better and more precise?
Old 03-09-2014, 10:20 AM   #10
s2d4
s2d4's Avatar
@jamesm looked into this when he did full close loop.
It's ridiculous how far off the previous forum golden childs had it so wrong.
A lot of the old dyno plots prior to 6-8 months ago had 13-14 AFR at WOT....
s2d4 is offline
Old 03-09-2014, 10:50 AM   #11
arghx7
Drives: car
I know I just threw out a long post and people are like "so what, what reading I believe? what should I do?" Let me throw in there that I'm all for having more instrumentation if you're willing to tolerate the science-experiment factor. If you can get a backpressure sensor, a pump-current type (Bosch, NTK) sensor in there, EGT, whatever, go for it. The question is--well now what do I do with this information? How do I interpret it and make decisions?
I have no doubt that one sensor in one location said one thing, another sensor in another location said something else. But what happened inside the cylinder ? We can make some general statements, but without a lab worth of equipment, I say: who knows? And even in a lab, it doesn't always reflect the reality of what's happening in the vehicle on the road.
One of the root causes of all of this hand-wringing are widely accepted internet rules of thumb for tuning. Rules of thumb are there for a reason, and they are still grounded in accumulated experiences of many people. But think about why we're having this debate.
Perfect example: "Don't go leaner than this AFR," subtly implying that you're a bad tuner/you don't know what you're doing/you're going to blow your car up if you are outside that range. That's not a bad kind of rule. We need rules like that, or nobody would accomplish anything doing day-to-day work. The natural result then becomes: "my x sensor at y location says I'm at 11.5, but what if I'm really at 12????? do I have a bad tuner/are people going to accuse me of being an incompetent tuner? Is this engine going to blow up?"
arghx7 is offline
Old 03-09-2014, 10:56 AM   #12
DJCarbine
Thupercharged
DJCarbine's Avatar
Well... looks like the innovate mtx is going back on.
Is the secondary o2 sensor port an acceptable place for a wideband?
2013 FRS
Vortech V3 11psi
DJCarbine is offline
Old 03-09-2014, 01:26 PM   #13
Xero-Limit
Xero-Limit's Avatar
Thanks for the detailed post, not sure how you got all that down so quick! They key here that you hit is "the AFR in the cylinder" is not the AFR in the pipe. The SC makes this even more challenging since we have lots of overlap in spots, and that nice fresh air is being force fed down the exhaust.
Ultimately the dyno is the best for this. You know when you go leaner and lose power you're too lean, and likewise if you go richer, stop dropping, and start misfiring--too rich. I was just amazed to compare the dyno AFR reading, to the onboard AFR, to what we estimate then from the dyno as the 11.5-12.5 best power range. Stock sensor was totally useless as it indicated as high as 14xxx for 12.5, and had little to no variation from there down to rich limit.
But at the same time you do get some correlation with some of the tunes we have done. Just a complete toss up since it is likely dependent on the boost, type of boost, and cam phasing.
Old 03-09-2014, 02:07 PM   #14
Shiv@Openflash
Shiv@Openflash's Avatar
Drives: 2013 FRS
20 years ago, Fred from Electromotive told me something I will never forget: "an Air/fuel Sensor ratio doesn't read air/fuel ratio. But rather oxygen presence in the exhaust and that they are all calibrated differently," Simple and obvious but after some thought you begin to realize that focusing on a number or comparing one sensor to an other and calling one "inaccurate" is faulty logic. What you want is repeatability above all else. If you know that the you get most knock resistance with best power X:1 nominal AFR with Y sensor, you shoot for that assuming you don't make any big changes to overlap or boost pressure. That may equate to Z:1 AFR on another sensor but that doesn't matter.
Shiv@Openflash is offline
is the front o2 sensor a wideband sensor? mad_sb Engine, Exhaust, Transmission 19 12-13-2015 02:20 PM
BRZ Navigation accuracy and features Don_SA BRZ First-Gen (2012+) — General Topics 41 05-06-2013 12:55 PM
Innovate Wideband Air/Fuel Ratio LC-1 Wideband Kit **Special Price** Titanmotorsports Audio/Visual, Electronics, Infotainment, NAV 2 09-14-2012 12:42 PM
Speedometer Accuracy MTeator Scion FR-S / Toyota 86 GT86 General Forum 16 08-22-2012 08:39 AM
An example of rumour accuracy. Dimman Scion FR-S / Toyota 86 GT86 General Forum 7 01-04-2011 08:53 PM
