Northern California NorCal
Old 03-08-2014, 05:46 PM   #1
SOLDIER [X]
Drives: 2014 SWP BRZ Limited
Scion Dealership for Warranty Work?
Hey all,
Just a quick question, my wife's Scion TC is having burning oil consumption problems. Burned 2.8 quarts in 5,000 miles and it just started doing it, or it may have and I just haven't noticed =/. In any case, I found a TSB regarding this engine and I think my wife's car falls under it:
http://www.newscionxb.com/attachment...sb-0094-11.pdf
Same engine as those cars. Anyone know a reputable Scion dealership in the bay area to do this?
SOLDIER [X] is offline   Reply With Quote
Old 03-08-2014, 05:53 PM   #2
connorlug
Drives: #1553 10 Series FRS
doesn't apply to your wifes tc unfortunately, what year is it?
that tsb was for mostly camrys/rav4s that had bad rings from the factory. mostly the 2007/2008s, but thats been fixed for a long time.
anyway, is the tc brand new or the older body style?
connorlug is offline   Reply With Quote
Old 03-08-2014, 06:14 PM   #3
SOLDIER [X]
It's the older body style. 2007 Scion TC, which is the same year those issues were had in the those cars. Same engine that exists in Camry's/Rav 4's, which doesn't make sense to me.
Old 03-08-2014, 06:49 PM   #4
SOLDIER [X]
Disregard, even though this falls under the 60,000 mile powertrain warranty (car is at 57,000) it does not qualify under the 60 months. Found the Scion TSB number but I can't find the tsb anywhere online: http://www.scionlife.com/forums/show...&postcount=138
HERE YOU GO:
S-SB-0024-11
Some 2007 – 2009 model year tC and 2008 – 2009 model year xB vehicles equipped with the
2AZ-FE engine may exhibit engine oil consumption. The piston assembly has been changed to
minimize oil consumption.
Old 03-09-2014, 01:59 AM   #5
HapaHaole
Drives: Grocery cart
If you need a copy of it I do have it, but here is an excerpt from it
S-SB-0024-11
August 11, 2011
2AZ-FE Engine Oil Consumption
Service Category
Engine/Hybrid System
Section
Lubrication
Market
USA
Applicability
Introduction
Some 2007 - 2009 model year tC and 2008 - 2009 model year xB vehicles equipped with the 2AZ-FE engine may exhibit engine oil consumption. The piston assembly has been changed to minimize oil consumption. Use the following repair procedure to address this condition.
Production Change Information
This TSB applies to vehicles produced BEFORE the Production Change Effective VINs shown below.
HapaHaole is offline   Reply With Quote
Old 03-09-2014, 03:56 AM   #6
SOLDIER [X]
S-SB-0024-11
August 11, 2011
Service Category
Section
Lubrication
Market
USA
Applicability
Introduction
If you have it, I'd love to take a look at it. At least it'd be good information just in case I need to get it fixed externally.
Old 03-09-2014, 01:36 PM   #7
HapaHaole
Pm me your email and I will send you the PDF.
SOLD: 2014 BRZ Limited WRB 6 Speed.
Old 03-09-2014, 04:58 PM   #8
SOLDIER [X]
PM Sent!
Old 02-05-2015, 11:15 AM   #9
SOLDIER [X]
Just going to bump this thread, after my complaint almost a year ago, Scion reached out and acknowledged there may be an issue where some Scion's may report excessive engine oil consumption that my have have been under the TSB. I have to get it checked and tested (oil plug, etc. sealed and me driven for a few months)
Once again, just asking if anyone knows of a good dealership to do this at, let me know.
Thanks!
Old 02-17-2015, 08:09 PM   #10
n0m0h0s
n0m0h0s's Avatar
Drives: #2148 frs 10 series
Send a message via AIM to n0m0h0s
Come to Hayward Toyota. I work there as a tech, been doing a lot of oil consumption tests. Should be no problem doing it to yours
n0m0h0s is offline   Reply With Quote
Old 02-19-2015, 11:08 AM   #11
SOLDIER [X]
Sad I missed this. What's your name and will you be in tomorrow (I have a doctors appointment so I'm currently off tomorrow).
Old 02-19-2015, 01:29 PM   #12
Clipdat
Proud of BOXER
Clipdat's Avatar
Drives: Subaru Boxer
I just got something in the mail similar to this for my tc. It basically says they're going to extend out the warranty for this issue until December of 2016. Seems like they're finally going to acknowledge the excessive oil consumption issues that these engines have. I should post up some pics of the letter.
Thanks!
Originally Posted by humfrz
I'm old and lazy
Old 02-19-2015, 02:27 PM   #13
SOLDIER [X]
It took them long enough. I was burning a quart a month when carpooling with my wife. What year is your TC?
Old 02-19-2015, 02:38 PM   #14
Clipdat
Proud of BOXER
Clipdat's Avatar
I have a 2007. It's burning probably the same amount as yours or maybe more.
In the letter it describes doing an oil consumption test where they seal the system and you drive ~1k miles and then come back to see how much oil was used.
My only fear of this is that over the course of the 1k testing miles it's going to be over a quart low by the time it's done with the test and that can't be good for the engine to be driving around like that.
I'm old and lazy
Dealership Recommendation For Warranty/Service? Bach415 Northern California 2 03-04-2014 01:19 AM
Cruise Control Warranty work? gdrider77 Issues | Warranty | Recalls / TSB 22 10-12-2013 05:23 AM
Complimentary maintenance + tuned ECU, will the dealership know and void my warranty? retrosmiths Issues | Warranty | Recalls / TSB 4 08-07-2013 07:27 PM
Does anybody work at a Lexus Dealership? PradiG Southern California 1 06-19-2013 07:09 PM
Warranty Work? Heero CANADA 9 12-27-2012 02:25 PM
