Car Nut
Drives: BMW 335d, Toyota Echo RS, FRS
Toyobaru Aftermarket Shock Options?
Haven't had much luck in searching around, but what are the options for aftermarket shocks to put with my Eibach Sportlines and sway bars?
It looks like there are a few options these days.
Koni has rear bolt-on replacements and front inserts (meaning you have to gut your stock struts). Bilstein has their B6 and B8 replacements which are bolt on. TRD Japan has some replacement shocks as well as a few other JDM brands. Cusco just came out with some. |
#3 | |
Car Nut
Drives: 2013 Scion FR-S, Raven, Manual
Bilstein B8's...full replacement, designed for lowered applications.
Drives: 2013 scion fr-s
I've been looking into this a lot myself, I'll be interested to hear more about them. I was looking at koni yellows myself, I didn't realize the front were inserts.
Car Nut
Looks like I'm going to go for Bilsteins.
Bilsteins are like 50%+ more than the Koni's, it might almost be cheaper to buy full set of used stock struts to gut.
Yeah there is at least one shop also (Turn in Concepts) who will sell you pre-built fronts as well.
| Aftermarket Exhaust Options | Moe | AFRICA | 49 | 03-03-2014 04:03 PM |
| Grill options aftermarket (Grillcraft) | rikdrt1 | Cosmetic Modification (Interior/Exterior/Lighting) | 16 | 01-02-2014 12:10 PM |
| Aftermarket options for fixing up rear fender body | edocura | Cosmetic Modification (Interior/Exterior/Lighting) | 1 | 08-13-2013 06:20 PM |
| Color options Camber Plates, Stress Bar, & Shock Mounts | GC_Adam | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 14 | 03-26-2013 01:08 PM |
| Aftermarket headunit Mounting options | encity5 | Electronics | Audio | NAV | Infotainment | 3 | 07-30-2012 09:49 AM |
