Old 03-06-2014, 02:33 PM   #1
Unraveled
Drives: 2013 Scion FRS
What's the Best Dealership in Miami to service an FRS
As the title states, I'm looking for the best dealership in Miami to service my 13' FRS...
I've had my fuel pump replaced once already to no avail at Headquarter Toyota. Second time they couldn't replicate the sound and gave me the run around.... Get into the car and bam crickets.
Other issues:
Rear Deck popping noise that has already been "fixed" once. Then some type of noise coming from around the shifter area below the radio. Shift leveler has been replaced. Noise starter after they replaced the Shift leveler.
What should I do guys? I feel like this Headquarter Toyota Service doesn't care about servicing a car under warranty. Scheduled an Appointment today to see if they can fix these issues once again, as the noise they produced has finally got to my last nerve. Plus I want to install my BC Coils after a solid fix before they has something else to blame....
Thanks in advance.
Unraveled is offline   Reply With Quote
Old 03-06-2014, 02:40 PM   #2
sshole
Posting this in your regional subforum would yield better/best results. I'm in VA and cannot recommend a single dealership in FL to fix your issues.
sshole is offline   Reply With Quote
Old 03-06-2014, 04:38 PM   #3
hunter3232792
hunter3232792's Avatar
Drives: FRS
ive never had a problem at kendall toyota on us1 you could try that one
hunter3232792 is offline   Reply With Quote
Old 03-06-2014, 04:57 PM   #4
Unraveled
Thanks! Have you had any problems with your Frs?
Old 03-07-2014, 11:09 AM   #5
hunter3232792
Drives: FRS
except for the crickets nope
Old 03-07-2014, 11:22 AM   #6
Rican_D
Rican_D's Avatar
Drives: Asphalt FR-S
West Kendall Toyota has good service
Rican_D is offline   Reply With Quote
Old 03-08-2014, 10:47 AM   #7
SHIFTER
SHIFTER's Avatar
Drives: Scion FR-S
It may be a tad bit of a drive - but Autonation Weston has always been decent for me.
Andrew
2013 Scion FR-S MT (Silver)
2011 Toyota Rav4 Sport V6 4wd (Silver)
SHIFTER is offline   Reply With Quote
Old 03-09-2014, 10:29 AM   #8
orangeblue
Drives: Whiteout
Kendall Toyota
orangeblue is offline   Reply With Quote
First service from dealership JayDee Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 24 04-02-2014 01:41 PM
Best dealership for service?? booyaka Northwest 6 01-17-2014 09:14 AM
Recommend a dealership for service radroach Northern California 3 05-21-2013 05:18 AM
***Calgary*** Which dealership did you buy from and how has there service been. Bu-Tang CANADA 1 03-28-2013 11:24 AM
Which dealership for first service? randomweather CANADA 1 12-23-2012 12:57 PM
