Drives: 2013 Argento
M/T CCOLD!
Transmission is TIGHT in cold weather. Thinking about a lighter weight gear oil. First and second is hard to engage in cold weather.
Any suggestions? Fred :-) 153® |
The SquadWhisperer
Drives: '13 Ultramarine FR-S (STX)
There are already so many threads on this.... The search button on this site sucks, but you can use google. Input this exactly as you see it. You can change the words after the ".com" to find what you want.
Site:http://www.ft86club.com hard shifting in cold |
Drives: Scion fr-s
shift over 3500rpm in very cold weather and it goes a lot smoother. also running MT-90 from redline.
Coming from a canucks |
The SquadWhisperer
PLEASE do not rev your engine to 3.5k before you shift when your engine is cold. Once it passes that first bar on the temp gauge do as you please, but your trans will likely be somewhat better by that point anyway.
I agree shifting above 3000rpm with a cold engine isn't a terribly good idea. I'm using MT90 and cold shifting is a little stiff but it goes away quickly. By the time the needle is above the low mark the transmission feels much better.
The factory fill doesn't like to cooperate when it's cold, different fluid will definitely help but I'm a little wary of the thin fluids at the edge of spec or thinner. |
#6 | |
Drives: Scion fr-s
It is better to keep a light throttle all the way up to 3500rpm, then shift, then put even greater load on the engine and shifting it at 1500 rpm.. |
Señor Member
Señor Member
Do not do as you please, just because you water temp is up to operating temps does not mean you oil temp is.
Drives: Whiteout
Your water temp can be 120 and the oil in the engine at 60-90 takes quite a bit for the oil to warm up.. I recommend a scangauge really helps see your warm up times and how hot the car runs under loads!
#10 | |
The SquadWhisperer
Of course throttle should be kept to a minimum as well, but that is beside the point. In my original post I should have been more clear. When the engine is warmed to the normal range you can certainly rev it to 3.5k before shifting (everything has obtained sufficient heat for that). Do not go balls out until your oil temp is up though. |
#11 |
Don't care
Drives: 2013 Whiteout FRS
just drive the car for 5-7 minutes and its fine. its normal and there is nothing you can do about it. Coming from someone that has a 500 gram knob, aftermarket shifter, amsoil fluid, positive shift kit and the rear stay bushing.
