Old 03-03-2014, 09:55 PM   #1
Porsche
Drives: 2013 BRZ Ltd. MT
BRZ battery warranty?
I think the battery in my 2013 BRZ Limited is about dead.
This thing was feeble from the day I took delivery. I charged it on my Schumacher smart charger the day I took it home. But this thing has always been weak. Fortunately, my BRZ always starts within three seconds, because I don't think this battery could turn over the engine for ten seconds straight, never mind make repeated attempts.
Does anyone know if the battery is covered under warranty? My car has less than 7000 miles on it, and is 20 months old.
I cannot find any reference at all to the battery in my Warranty & Maintenance Booklet. Maybe I overlooked it. I was unsuccessful in searching for an electronic copy of this booklet, hoping to employ the text search feature.
So, can anyone help here?
And, while we're on the subject of Subaru battery life, has anyone else had a similar experience with a weak battery with poor life?
I've only replaced one battery in over 40 years and that was on an 8-year-old Mazda. My S2000 OEM battery is going strong and it's 8 years old, although, admittedly, it has spent much of its life connected to a battery tender.
Porsche is offline   Reply With Quote
Old 03-03-2014, 10:07 PM   #2
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
It would be covered under the standard 3-year/36K warranty.
-alex
The Following User Says Thank You to mav1178 For This Useful Post:
Porsche (03-03-2014)
Old 03-04-2014, 10:43 PM   #3
zinzan
zinzan's Avatar
Drives: Subaru BRZ 2014 Limited WRB
Is smart charging a battery a common practice? I used to keep a smart trickle charger on my car battery when I was consulting and would not drive my car for months at a time, but that was years ago. I think I still have that trickle charger, but haven't used it in probably 12 years.
I've never heard of using a "battery tender" or smart charger on a daily driver. Of course, I don't know if OP's BRZ is a DD.
-Z
zinzan is offline   Reply With Quote
Old 03-05-2014, 01:09 AM   #4
qqzj
Drives: MDX, Camry
I think the battery is weak. I have lost power twice due to battery issues. Both times I used battery tender to resurrect it. It works fine, but I do not have much confidence in it. Hopefully it will die in three years and I can get a new one. BTW, my Acura's battery is still going strong after 7.5 years. I believe in the Jap brands, Honda>Sub>Toyota in terms of quality of products made.
qqzj is offline   Reply With Quote
Old 03-05-2014, 03:21 AM   #5
Porsche
Yes, thanks, I know. I was wondering whether Subaru replaced the batteries under warranty. It could go either way, and I wouldn't be surprised. The thing is, they do not include the battery in the long list of items that ARE covered, and the battery is a pretty obvious component.
I haven't taken it in to the dealer, yet.
However, I did confirm today, after some tests, that it's on its last legs. After a full charge, and with no further load apart from the ECU and radio memories, etc., 16 hours later the battery registered a mere 12.4 volts. It's done.
It should have registered 12.7 volts, or higher. A few hours after removing the charger from my S2000 battery, it registered 13.1 volts. Ten minutes after a 100% charge, the Subaru battery had already dropped to a mere 12.5 volts.
This Subaru Panasonic(?) battery has been poor from day one.
I'll bet it does not work fine; I'll bet it tests at low voltage, and like mine, it just barely gets the job done. But, as you say, you cannot trust it. Just like mine, although yours might be a bit better than mine.
Your dealer can put a load tester on it and confirm that you need a new battery.
I would not wait. Take it in and have it tested. Tell them it failed already, twice.
When they give you a new battery, come back and thank me.
Old 03-06-2014, 12:23 PM   #6
zc06_kisstherain
zc06_kisstherain's Avatar
Drives: SWP BRZ
mine died completely from not driving for a week and due to cold weather.
I re-charged with battery charger for overnight and it brought life back.
yeah BRZ's stock battery seems very weak.
Old 03-06-2014, 01:19 PM   #7
AznBRZer
Drives: 16 CBS WRX Limited
I forgot my cabin light one night and the battery was still going strong the next morning. YMMV?
AznBRZer is offline   Reply With Quote
Old 03-06-2014, 01:24 PM   #8
Thorpedo
The SquadWhisperer
Drives: '13 Ultramarine FR-S (STX)
Mine is in storage and has been started twice in the last 4 months. Always starts strong.
Check your load when everything is off. I never trusted mere static voltages to be a good indication of battery health.
Thorpedo is offline   Reply With Quote
Old 06-28-2014, 02:20 AM   #9
quark
Battery too small!!
Mine was completely flat after 1 week without use.
No interior light, automatic inlock etc.
Only mod is android stereo, but this has been fine for a few weeks
1 hour charge at 4amps was enough to start.
Has anyone measured the power draw when the car is off?
quark is offline   Reply With Quote
Old 06-28-2014, 02:30 AM   #10
ZionsWrath
Thanks
ZionsWrath's Avatar
Mine sat under a mountain of ice for at least a month and didnt hesitate to start.
Old 06-28-2014, 02:36 AM   #11
quark
Nice !!
Old 06-30-2014, 12:00 PM   #12
Scenic Driver
Drives: 13 Subaru BRZ, 02 Audi TTQ
Mine sat under a similar mountain for 2 weeks and started fine
Scenic Driver is offline   Reply With Quote
The Following User Says Thank You to Scenic Driver For This Useful Post:
ZionsWrath (06-30-2014)
Old 06-30-2014, 12:23 PM   #13
ZionsWrath
Thanks
ZionsWrath's Avatar
You win
The Following User Says Thank You to ZionsWrath For This Useful Post:
chaoskaze (07-05-2014)
Old 07-01-2014, 01:57 AM   #14
quark
Update:
Turns out the issue was the boot/trunk wasn't closed properly and the battery drained after 48 hours
More info here:
http://www.ft86club.com/forums/showt...=1#post1824379
Has anyone tried ETX-9 8Ah AGM Battery customfab87 Tracking / Autocross / HPDE / Drifting 8 01-11-2014 09:02 PM
Battery tray for Braille 21lb battery? lordtakuban Engine, Exhaust, Transmission 4 09-10-2013 08:55 AM
battery jkr Engine, Exhaust, Transmission 1 04-11-2013 01:03 PM
Help with Car Battery Synack Off-Topic Lounge [WARNING: NO POLITICS] 0 01-13-2013 10:05 PM
TR-B1500 battery and billet battery tray install. mines13 DIY (Do-It-Yourself) Guides 8 12-07-2012 03:59 PM
