Drives: 2014 Subaru BRZ Premium - Red
strut bar help!
swapped my cusco strut bar and power brace to the aem 1-piece. looks like i stripped both the screw and metal piece it screws on to. is there a fix to this? will i be ok running without it? pls advise...
Just a dude
Drives: Scion FR-S 2013
How tight? That only has to be 12ft/lbs...
Helix oil be best way or re thread slightly larger and new accommodating bolt.
in the pic the hole of the bar itself is in the way of the screw from screwing in straight. i kept turning the screw thinking it would straighten out but did not happen. anyways, its the only screw that isn't lined up to the bar.
tell me about helix oil. i can screw about 2 threads but then it stops and becomes loose so i stopped. now even though it bothers me will it mess up anything if i run it without a screw? i don't want to have to pay to get it fixed. |
#4 | |
fastest frs in sbg
Drives: sick ass ultramarine frs
2013 ultramarine frs sold
2014 turbo ultramarine frs Sold 2014 firestorm frs |
#5 | |
Just a dude
![]() And to OP ya there's a lot of meat on that bracket section. I'd dremel that bracket hole out a tad more to give lots of way for next bolt to go in perfectly straight, late now but that likely would have prevented this for sure. If you don't want hassle of Heli coil etc you could goto a bolt shop get very next size bolt up metric or imperial "least" size +, and a tap die for that size and give it a whirl, just a thought.
Have you tried taking the bar off and threading a clean bolt into that hole? To me it looks like the problem is the bar stripped the bolt, but the threaded hole looks ok?
If you didn't do it this way, here's what I'd recommend anytime you need to assemble something:
Hand thread in every bolt first, but don't snug them, let the whole assembly float. If a bolt doesn't want to cooperate, DON'T force it! Check fitments again and maybe loosen some bolts if they will allow a little more play. Never tighten bolts down before they're all threaded in. If it started to cross thread, did the bolt actually thread into the hole much at all? Or did it start to thread, get tight, and then gall out the first couple threads? You might be able to chase the threads with a thread cutter or thread chaser. |
| Strut Bar Review: AEM Strut Bar Thoughts and Experiences | wu_dot_com | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 20 | 03-08-2019 04:33 PM |
| Lowering Springs|Alignment Kits|Strut bar|Sway Bars|Strut Mount +More | SOURCE,LLC | Brakes, Suspension, Chassis | 445 | 05-11-2015 05:41 PM |
| "Strut" Your Stuff With A BeatRush Strut Tower Brace // DSG PERFORMANCE | Jason@DSG | Groupbuys | 14 | 12-31-2013 09:06 AM |
| WTB Cusco Carbon Fiber Front Strut Bar w/ MCB and Cusco Carbon Fiber Rear Strut Bar | FR-S Matt | Want-To-Buy Requests | 0 | 12-04-2013 05:10 PM |
| FR-S strut. | JohnJohn86 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 34 | 12-30-2012 09:01 PM |
