Drives: White
RX330 HID retrofit
This'll be a work in progress as I'm not finished yet, but I'll be retrofitting some RX330 projectors (also found in newer Maximas, RX-8s and MDXs) into the FR-S using OEM Matsushita ballasts and 85122+ OEM 4300k bulbs.
I'm converting the new HIDs to bi-xenon by adding solenoids and shields from some Morimoto Mini 6.0s. The stock high beams have been converted to HIRs, so I should have plenty of high beam with the addition of high beam to the RX330s. This mod is designed to give me more usable light in general and give a nice clean look on the front of the car. No 6000k-8000k crap, no LED rings, no flashy colors. Housings will be done in a simple satin black to match the stock plastics. I started with a pair of Maxima headlights from eBay, removed the projectors and worked from there. Pictured: Fitting bi-xenon sheild/solenoid to freshly cut-down Maxima shield ![]() Pictured: Clear lenses installed, shield modified (ignore the reflection off the cars above the cutoff) ![]() Pictured: Some Hot Lava nudity! ![]() Pictured: Maxima HID on left -- FR-S halogen on right. I can make this work ![]() More to come as time allows. |
Drives: White
Well, the projector isn't a direct bolt-in, but as far as retrofits go, this is very easy. The projectors mounting/shield needed to be trimmed to match the stock projector and the Dremel had a little work to do on the housing, but it works well.
Pictured: Lots of mess, but the projector fits very well
| FRS Headlight Retrofit | TakeNoL | Cosmetic Modification (Interior/Exterior/Lighting) | 5 | 08-28-2013 08:46 PM |
| G37 Headlight Retrofit | retrosmiths | Cosmetic Modification (Interior/Exterior/Lighting) | 1 | 07-14-2013 02:33 AM |
| Retrofit time | markmatley | Hawaii | 7 | 01-13-2013 09:56 PM |
| HID Retrofit Kit install | Jidonsu | NY / NJ / CT / PA | 1 | 08-04-2012 01:24 AM |
| Need Expert on Retrofit !! | Ericfrs | Cosmetic Modification (Interior/Exterior/Lighting) | 3 | 07-22-2012 12:22 PM |
