Old 02-26-2014, 03:01 AM   #1
sosick
fastest frs in sbg
sosick's Avatar
Drives: sick ass ultramarine frs
Intake dip
Anyone with or without oft and an aftermarket intake still get the dip after reving it alil? Have u solved it? If so how? Thanks in advance!
Im refering to...i rev up the engine to about 3k completely let go and the rpm drop to about 500 and acts like its gonna die. Then goes back up to about 800
2013 ultramarine frs sold
2014 turbo ultramarine frs Sold
2014 firestorm frs
sosick is offline   Reply With Quote
Old 02-26-2014, 02:09 PM   #2
mid_life_crisis
Drives: FR-S 10 #103 AT
Originally Posted by Prowl647 View Post
Intake won't solve the dip issue. I have the full perrin cai and it did nothing for the dip. That's of course straight butt dyno but judging by the dynos posted I am re affirmed. I recently ordered the oft+ofh and received the tablet first. Installed stg 1 map which makes rev range smoother and flattens out that dip quite noticeably. Once the header gets here I am hoping the dip will be eliminated
I don't think you guys are talking about the same dip. I'm pretty sure the O/P is referring to the problem some guys have where they blip the throttle and even though they don't let up on the pedal, the rpm drops as if they did.
From what I have read, the dip Prowl is referring to requires either FI or a really well designed header to completely eliminate, although a good tune will get you close. I have no idea what to do about what sosick asked about.
The Following User Says Thank You to mid_life_crisis For This Useful Post:
sosick (02-26-2014)
Old 02-26-2014, 03:18 PM   #3
ramiram1984
Drives: 2016 STi DGM
Anything w/o FI and you'll still have a dip...maybe even with some FI set ups, that dip may still exist.
Good luck!
-2014 SSM BRZ MT
ramiram1984 is offline   Reply With Quote
The Following User Says Thank You to ramiram1984 For This Useful Post:
sosick (02-26-2014)
Old 02-26-2014, 03:55 PM   #4
sosick
fastest frs in sbg
sosick's Avatar
2014 firestorm frs
Old 02-26-2014, 03:59 PM   #5
ramiram1984
Ohhh, you mean the idle! haha, totally different.
Where's the idle after warm up? Look at the owner's manual and it should tell ya where the idle after warm up should be.
-2014 SSM BRZ MT
sosick (02-26-2014)
Old 02-26-2014, 04:23 PM   #6
mid_life_crisis
Good luck!
I don't see any dip here and it's just a header; no tune, intake or additional exhaust work, and definitely no FI. Slight drop below the dip, nice little gain at high rpm: all in all a nice looking NA power curve.
http://www.ft86club.com/forums/showthread.php?t=52835
Old 02-26-2014, 04:25 PM   #7
ramiram1984
hehe...it is a nice dyno.
-2014 SSM BRZ MT
Old 02-26-2014, 04:42 PM   #8
sosick
fastest frs in sbg
sosick's Avatar
It idles normal until i rev it
2014 firestorm frs
Old 02-26-2014, 05:25 PM   #9
StormTrooper
StormTrooper's Avatar
Drives: Pavement MT GR86
Stock I had what I'd call idle hunting..... Going from 500 go 1k to 700 back to 1k then down to 500 which if I remember is the warmed up idle.
With the tune I have, the idle is now 700 and I've had zero hunting.
GR86 MT premium
StormTrooper is offline   Reply With Quote
The Following User Says Thank You to StormTrooper For This Useful Post:
sosick (02-26-2014)
Old 02-26-2014, 05:33 PM   #10
FrsDuke
Fanboy
FrsDuke's Avatar
Drives: 2013 ultramarine frs
Look at the service bulletin sticky. Go get an updated calibration from your dealership for free. Fixes idle issue.
I'm done helping those who won't help themselves.
TL;DR:
-Duke
FrsDuke is offline   Reply With Quote
The Following User Says Thank You to FrsDuke For This Useful Post:
sosick (02-26-2014)
Old 02-26-2014, 07:31 PM   #11
sosick
fastest frs in sbg
sosick's Avatar
I have the el stage 2 v1.55 from oft but it didnt help
2014 firestorm frs
Old 02-26-2014, 07:31 PM   #12
sosick
fastest frs in sbg
sosick's Avatar
Wat about my tune then?
2014 firestorm frs
Old 02-26-2014, 07:59 PM   #13
FrsDuke
Fanboy
FrsDuke's Avatar
What mods do you have on the car? Is it only when you release the throttle from high rpm that it goes low? Does it bog? Does it stay low? What is your base calibration? The b01c or d calibrations have improved idle compared to the a01x calibrations that shiv's tunes are based on. If you are on anything other than b01x it may well help.
TL;DR:
-Duke
sosick (03-05-2014)
Old 02-27-2014, 01:40 AM   #14
jflogerzi
jflogerzi's Avatar
With the oft I dont have the idle dip except when the a/c is on. Stg 2 uel E85
Sent from my SGH-T999 using Tapatalk
2013 Series 10 FRS #553
The Following User Says Thank You to jflogerzi For This Useful Post:
sosick (03-05-2014)
Okada / Ignition Projects / Cusco / Megan / aFe Intake & Filter / Agency Power Intake eauto Engine, Exhaust, Bolt-Ons 299 10-15-2014 02:44 PM
.: GReddy Air Intake System · Increases intake airflow · 4 Layer filter :. Speed Element Engine, Exhaust, Bolt-Ons 14 05-20-2013 07:06 PM
HKS intake setup VS Injen intake,,,what are your thoughts? JDMrolla Engine, Exhaust, Transmission 4 10-11-2012 02:31 PM
