Old 02-19-2014, 03:53 AM   #1
ang31ito
ang31ito's Avatar
Drives: Scion FRS 2013 - Whiteout
Orlando shop for coilovers install?
I'm looking to have BC extreme low coilovers installed same day at an Orlando shop. Can any recommend a good place that wont break my wallet? The BCs I want go for $995 shipped. I'm looking to pay exactly that for parts at a dealer and also leave with an alignment. How much for install + alignment?
ang31ito is offline   Reply With Quote
Old 02-19-2014, 06:51 AM   #2
FR-S Matt
$1600.
Better off buying a jack, two jackstands, and a ratchet set and swapping them out yourself. Since the BC's already have top hats, this is a way easy install. Then go get an alignment. All of that would cost you probably $1150 total.
Old 02-19-2014, 08:43 AM   #3
Ryaquinn
Ryaquinn's Avatar
Drives: FRS
^ much agreed. Very easy install
Ryaquinn is offline   Reply With Quote
Old 02-19-2014, 09:28 AM   #4
ang31ito
ang31ito's Avatar
Thanks for the advice. Can you point me to a good DIY for our cars? Also, I don't know about ride stiffness. What would you recommend? This is a DD. I want to go as low as possible without rubbing but idk that much about spring rates.
Old 02-19-2014, 09:43 AM   #5
Malt
Drives: 2015 WRX
Keep in mind you'll need some means of adjusting the rear camber with coilovers if you lower the car. As someone who was quoted 6 hours of labor for the whiteline rear upper adjustment bolts (didnt install them because of that) and installed an ecentric bolt for the rear camber I can tell you to just go ahead and get rear lower adjustable control arms. If you don't your rear alignment will surely be off with no way to get it dialed in correctly. My alignment is STILL not right and I've already spent more money parts and alignments than I would have if I had of just going ahead with a rear lower control arm.
Malt is offline   Reply With Quote
Old 02-19-2014, 10:12 AM   #6
chonody
Drives: 2013 Subaru BRZ
I would look at Circuit Motorsports. They are on North Forsyth off of University. They did my springs and a bunch of other stuff and they are great. Plus they are great friends with the guys at BC so they might be able to get you a deal on coilovers.
chonody is offline   Reply With Quote
Old 02-19-2014, 10:13 AM   #7
Ryaquinn
Ryaquinn's Avatar
Drives: FRS
http://www.ft86club.com/forums/showthread.php?t=12864
Old 02-19-2014, 11:41 AM   #8
ang31ito
ang31ito's Avatar
I was looking into lower control arms for the look when a non-stock color is used. In the DIY I see nothing that mentioned you absolutely need it. Please explain why some have gone without.
Old 02-19-2014, 11:58 AM   #9
Malt
Drives: 2015 WRX
Because they don't care about alignments or didn't lower their car which allowed them to get away with just an eccentric bolt for adjustment. With my 1" lower my camber went to -2.4 on the right and -1.9 on the left. The eccentric bolt only got me to -2.3 and -2. I'll need to either install those upper bushings (can't install those myself and the price of installation will basically be what lower control arms cost.
Old 02-19-2014, 11:58 AM   #10
Redlinedfrs86
Redlinedfrs86's Avatar
Drives: 2013 Firestorm FR-S
@ang31ito contact @Rev Works....
Redlinedfrs86 is offline   Reply With Quote
Old 02-19-2014, 11:59 AM   #11
ang31ito
ang31ito's Avatar
Thanks @Malt and @Redlinedfrs86. I sent them a message thru their website.
Old 02-19-2014, 12:41 PM   #12
Rev Works
Rev Works's Avatar
Drives: 2013 STi
Hey buddy! We can get you taken care of for sure for the install and alignment. We have an in house alignment machine and can also get the parts, so we would be a one stop shop for you! I am sending you a PM with more details
-Matt
Rev Works is offline   Reply With Quote
Old 02-19-2014, 12:54 PM   #13
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
According to the sponsors list here: http://www.ft86club.com/forums/ad/ad_thesponsors.php
Circuit Motorsports and Titan are both in Orlando. Rev Works is also but they haven't filled out their info for the sponsor list I'm assuming.
I've never dealt with Circuit but Titan is great and Rev Works has good reviews here also
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
>>Circuit Motorsports - Full Performance Shop - Central FL / Orlando - 86 Specials << Circuit Motorsports Southeast 204 10-05-2016 01:27 PM
Air suspension install shop Justin91M Southern California 4 02-16-2014 12:33 PM
anyone know a good audio install shop NYCsubaruBRZ NY / NJ / CT / PA 6 01-16-2014 10:22 AM
nyc shop for backup cam install? Aloxi NY / NJ / CT / PA 10 07-14-2013 10:45 PM
Detail shop in Orlando, FL? Enraged21 Southeast 8 03-23-2013 09:43 PM
