After market LCA needed?
I currently have a swp brz, I have 18x9.5 gtv02s on the way which will be wrapped in 245/35 Front and 265/35 rear, followed up with fortune 500 coilovers. Im looking for a 1-1.5" drop, My question is for DD and possible track once or twice a year what would idea camber setup be?
Just a dude
Drives: Scion FR-S 2013
Be noted that when you go lower then 1.5 inches (height) other handling affects take place and needs if you want it to handle properly. All that said and if you're staying higher then -1.5 inches drop..why run same size tires all around ie : 255/35/18 ??
Drives: Attitude
There's no camber adjustment stock. When you drop the car, you'll find out how much it changes and it WILL change. So the question isn't whether or not you need an LCA, it's which LCA fits your need for ±3° of camber and minor track duty if any. You will likely need some toe correction as well - you don't seem like you'd want to shell out for new adjustable toe links.
For your suggested use perhaps the SPC kit will fit: stamped steel just like stock arms except with an adjustable end and an offset bushing for the toe links to correct toe changes as well. |
So then I'm,looking at whiteline LCA and for the front chamber bolts and I should be good then
Sent from my VS980 4G using Tapatalk |
Just a dude
Good choice on lca, pretty sure fortune coils have camber plates? If so shouldn't need camber bolts but they're cheap so sure grab em in case you can't get enough outta the plates.
Drives: BRZ - Dark Grey
To parrot @OrbitalEllipses go with the SPC control arms. They're much much cheaper than whiteline and will serve the same purpose.
SPC = $208 Whiteline = $494 They do the same thing, SPC also has toe adjustment. I have the SPC's and they're just fine - I don't see why anyone would want to spend more than twice as much on the whitelines... I guess they're pretty and gold? but honestly they're under your car. |
#7 | |
Drives: 2013 Whiteout FRS
#8 | |
Drives: Attitude
sorry, not sure i understand, failure prone? how so?
#10 |
Has anyone had any luck with the Buddy Club P1 LCA?
#11 | |
Drives: 13' Subaru BRZ Limited SWP 6MT
@brz Islander
I'm running Fortune Auto 500's and love them. My BRZ is planted, controlled, but subtle and smooth over bumps and rough roads. The ride is superior to stock in every way, which was also very good. Fortune's digressive piston, coupled with their custom valving and dyno matched sets makes these the best coilovers for the money IMO. If you do get Fortunes, I highly recommend the front bearing top hat, and potentially Swift spring upgrade. Also the only other coilovers near this price you might consider are the RS-R Blacks. From what I've read, anything more than a 40mm drop negatively affects handling due to the changed suspension geometry. That being said, I liked the look of my car at 44mm (1.75") drop, so that is my current setup. So you know, the Fortune Auto 500's provide a 3" front drop and a 2" rear drop; more rear would be possible with Stance like LCAs. At a 1.75" drop, my front camber was approx -1.5°, and the rear was -2.9°. Because this is my daily driver, I chose to run a factory spec alignment of -0.1° front and -1.2° rear. The Fortune front top camber plates had ample adjustment for this. The rear of course was a different story. The new SPC rear LCAs have more than enough camber adjustment, but the problem is rear LCAs mount at the rear of the hub, and as you push the top of the wheel out, you also push the toe out. Thus the most camber I was able to get with my toe maxed out was -2.4°. So instead of raising my car or running more rear camber, I installed SPC rear toe arms, which provided the necessary adjustment for rear factory spec. Yes the SPC LCAs come with toe bushings, but the cost to have the old bushings pressed out and the new ones pressed in would have almost equaled the $180 I paid for toe arms. Also toe arms are better for adjusting, and won't slip like the bushing can. I used to think people wasted their money on the whiteline rear bushing set, but reality is they adjust camber on the top control arm, and thus don't induce toe, like an LCA does. If doing it over, I might have gone with Whiteline bushings, but I do like the ease LCAs provide to return my car to stock on my own if I so desire. Quote:
| Market value of FRS with Vortech SC | reesmicm | Scion FR-S / Toyota 86 GT86 General Forum | 34 | 02-10-2014 05:32 PM |
| After Market clutchs? | jc1993 | Engine, Exhaust, Transmission | 3 | 10-22-2013 08:29 PM |
| After market security | shiud | Electronics | Audio | NAV | Infotainment | 5 | 09-28-2012 03:59 PM |
| Question about US and OZ market | FT86_Zero | Scion FR-S / Toyota 86 GT86 General Forum | 2 | 06-12-2012 11:08 PM |
| how many dads here are in the market for a FR-S? | stlgrym3 | Scion FR-S / Toyota 86 GT86 General Forum | 52 | 02-21-2012 12:35 AM |
