Old 02-16-2014, 11:44 PM   #1
Simon99
Simon99's Avatar
Drives: 2013 BRZ Limited WRB
Can afford one: clear bra or opticoat pro ?
Hey I'm getting my BRZ delivered in march and I want to start taking care of her right away. Do you guys think I'm better off with a clear bra to revent rock chips or will the extra thickness fron opticoat protect it a bit ? Also, will opticoat over clear bra prevent yellowing of said bra ?
Sent from my SGH-I337M using Tapatalk
Originally Posted by VesperLynn
This car has allowed car enthusiasts to come from all different walks of life, car cultures, and brands. Just as a panda is black, white, and Asian; the 86 is Toyota, Subaru, and downright fucking sexy.
Simon99 is offline   Reply With Quote
Old 02-17-2014, 12:36 AM   #2
504
504's Avatar
Drives: 2014 86 GTS
opticoat wont do a thing to protect the paint from rock chips, its basically adding another 2 micron thick layer of clear coat which has wax-like properties. once installed, you cannot do any form of paint correction as you will remove the coating. Clear bras are made and installed for the primary purpose of protecting paint from rocks and other road debris and modern paint protection films like Xpel Ultimate protect paint from UV radiation and even have their own self healing layer which returns the film to perfect condition even after heavy scratching.
Opticoat helps with washing the car IMO and keeping it clean, clear bras actually do the protection. Xpel ultimate has a 10 year warranty again yellowing so you should be fine in that department, I'm not sure how long opticoat would last with a self healing film like the Xpel
504 is offline   Reply With Quote
The Following User Says Thank You to 504 For This Useful Post:
SirBrass (02-17-2014)
Old 02-17-2014, 01:26 AM   #3
SirBrass
Trust me, I'm the Doctor
SirBrass's Avatar
You'll need to new car prep, paint correct, & optiguard first before clear bra if you plan to do both.
And optiguard does help with rock chips (not add well as vinyl clear bra), as it's a ceramic coating, whereas the factory paint is thin water based paint. The optiguard is harder, even if only 2 microns thick.
Darker paint jobs seem to look better with c quartz instead of optiguard, I'm told.
Something to keep in mind.
I'm on my phone so if I make mistakes, blame Sportsguy83
^GT5 Replay Photo Mode^
Old 02-17-2014, 02:03 PM   #4
Simon99
Simon99's Avatar
I though paint correction was only done on a used car with paint damage... since my car is new it shouldn't need it ?
I will check out Xpel, I only had 3M in mind and heard about yellowing after 3-4 years. But it's sure that giving the car a permanent shiny look is something desired.
Old 02-17-2014, 02:04 PM   #5
SirBrass
SirBrass's Avatar
Paint correction will most likely be needed because these cars have VERY soft paint. If you accidentally let the dealership wash the car... you'll need paint correction. There's already swirls, I guarantee it.
Old 02-17-2014, 03:28 PM   #6
Frost
CASC-OR T.A. Director
Frost's Avatar
Drives: '13 Prius, '22 BRZ
Opticoat first. Always. Get the foundation fixed then apply the bra.
Want the best quality track times for new personal bests? Come on out to Ontario Time Attack!!!
OTA LIVE TIMING LINK
Frost is offline   Reply With Quote
Old 02-17-2014, 09:17 PM   #7
Hamza7
Drives: MiniVan
Both are very good forms of protection. As thickness goes Clear Bras are way thicker but if you have paint defects underneath the bra then it's better to get Opti-Coat Pro first. A lot of new cars even from factory sometimes have defects so it's recommended to get the paint inspected, corrected in need be and then protected with Opti-Coat Pro then you can go with Clear Bra and then Opti-Coat Pro on top of the clear bra (so self cleaning properties will make the clear bra dirtier than the rest of the car where opticoat is the top layer.)
Hamza7 is offline   Reply With Quote
Old 02-17-2014, 09:18 PM   #8
Simon99
Simon99's Avatar
Thanks Hamza, are you from Toronto (TM3 forums)? You recommended Vlad in Ottawa for my detailing is that possible ?
Old 02-17-2014, 09:36 PM   #9
Hamza7
Drives: MiniVan
Hey Simon,
I thought your username looked oddly familiar. Yes I also sponsor TM3. Vlad is Opti-Coat authorized.
Old 02-17-2014, 09:41 PM   #10
Simon99
Simon99's Avatar
Hey Simon,
Too bad you're 6 hours from here... I'd have you do it I'll email Vlad again. Just to make sure, Opti-Coat Pro over 2.0 ? And how do you feel about C.Quartz/GTechniq EXOv2 ?
Old 02-17-2014, 10:00 PM   #11
Hamza7
Drives: MiniVan
Great, Vlad is a good detailer and I'm sure you'll be happy with his work. Actually I'm having lunch with him because he's in town this week so I'll make sure he does a good job. I wish teleportation was a thing so then I could travel all over the place to detail but honestly they are great detailers all over it's just hard sometimes to find them.
It's definitely a tough decision on choosing a coating and I always recommend to ask the detailer applying the coatings to your car on what he thinks.
The way I see it is if you use your car like a car (parked outside, more than 20K km a year, drive it all the time) then get Opti-Coat Pro because it provides the most protection for your vehicle. 2.0 is also a good coating but if a Pro installer is detailing your ride then most likely will be the same price, pro provides more protection.
Cquartz is good coating for cars that are driven a little bit more carefully so parked inside, babied (of course if you drive your car a lot of park outside then it can be babied as well) and if you really care about the looks then go with CQuartz because outright it looks great, it provides more depth when applied on dark colours so if your silver or white then forget about it.
Let me know if I didn't explain properly, sometimes I forget I'm not talking to other detailers but rather regular people.
- Hamza
Old 02-17-2014, 10:04 PM   #12
Simon99
Simon99's Avatar
- Hamza
Euuuuhh maybe some background info can help you ! The care will be babied, stored outside during nice summer days and maybe temporarely placed inside during rains, stored the whole winter in a heated garage. It's the World Rally Blue (the Subaru blue) and I don't know if that classifies as dark or light color...
I just don't know since in the end its not a lamborghini so i dont know if double the price for C.Quartz is worth it
i actually thoroughly emailed Vlad but I know he's closed for the winter. I met him once though and hes an amazing guy, really honest and dedicated.
Old 02-18-2014, 06:38 AM   #13
CruiseZen
CruiseZen's Avatar
Drives: 2014 Ultramarine 6MT FR-S Monogram
I'm planning on getting Opti-Coat on my new car but worry a little about how a clear bra will look after a few years. While the areas covered by the bra would be protected from UV rays, the unprotected areas will fade. I've seen this on quite a few cars, especially with paint colors that are more susceptible to UV. Would be curious if anyone who has a clear bra has experienced this.
CruiseZen is offline   Reply With Quote
Old 02-18-2014, 06:57 AM   #14
Heru Farukon
Drives: MOARLOW BEEARRZEE
If you want a clear bra, I would do the full front clip (ie full hood, full fenders, bumper.
And either use 3M or Xpel ultimate(baller stuff).
I use Xpel since I install them for a living and can get them for dirt cheap! Hopefully will have the whole car wrapped in 3M so it's protected and no fading, already did my full clip + headlights
Sent from my SM-N900W8 using Tapatalk
Heru Farukon is offline   Reply With Quote
Recommendations for Clear Bra + Opticoat Pro in San Diego area jube Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 6 08-22-2013 10:01 PM
Opticoat/Clear Bra in Union/Essex in NJ rhood168 NY / NJ / CT / PA 2 04-28-2013 11:13 PM
Want Opticoat, but clear bra on. Siberian Husky Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 9 01-14-2013 02:44 AM
Can I afford this car? tomjh704 Scion FR-S / Toyota 86 GT86 General Forum 89 04-20-2012 06:42 AM
