Old 02-12-2014, 02:36 PM   #1
Cypher2
Drives: 2013 Ultramarine FR-S
Where do you guys get your hubcentric rings?
I am about to pull the trigger on some Advan RSII +48 wheels. According to my research that means that I need a 56.1 to 73mm hubcentric ring. I want a set that are not plastic because I've heard of them melting under track conditions.
I think that the 73mm bore of aftermarket wheels is pretty common, so where do you guys get your non-plastic hubcentric rings? I would probably be buying my wheels from Evasive Motorsports, and on their site they have 56 to 73... is that close enough?
Thanks.
Cypher2 is offline   Reply With Quote
Old 02-12-2014, 02:41 PM   #2
ayau
Drives: Some rust bucket
Thanks.
Even metal rings will melt/crack/etc under track conditions. Rings aren't needed as long as you mount the wheel in the proper star pattern.
Someone help me find Hubcentric rings!!! Rick Boxx Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 12 01-24-2017 03:17 PM
Do you need hubcentric rings on aftermarket wheels? ayau Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 36 01-18-2017 06:08 PM
Hubcentric Rings Draco-REX Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 57 06-08-2016 01:42 PM
fs: Hubcentric rings, solve wheel vibration! pitstops Wheels and Tires 0 07-25-2013 05:05 PM
Which Hubcentric Rings do I need? RPF1 Hanakuso Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 3 11-20-2012 09:56 AM
