Drives: 2020 BRZ tS #54
Toms USDM sides not lighting up!?
Just installed toms USDM version and the sides wont light up for some reason... I do have winjets headlights also.. I did watch the video of the ft86speed and he mentions that the sides light up when you turn the headlights on but im sure they have a facorty scion headlights. .. could that be the reason mine is not ligthing up? The winjet headlights could be darwing power or something?
I did replace the flasher relay that came with the tom's lights.. signals/hazards/breaks/main rear lights work fine just the side markers of it dont light up.. Part number is 81500-TZN60 on box but the instructions 81500-TZN60-01 Could it be they sent me the wrong ones? if so ill be pissed off.. going to re check the wiring tomorrow..Thanks guys |
Drives: 2013 whiteout FRS 6mt
My guess is you have the wrong tail lights. You might have the usdm jdm version, which means straight plug and play (no re pinning the wires). What you want is the USDM DOT approve versions.
Drives: 87 Supra, 13 FRS, 05 FXT
Post the link of the one that you purchased, you might've gotten the JDM ones.
Drives: 86 ZN6
was "toms" or "depo" black or red on the box?
black = USDM red = JDM |
Glorious BRZ Master Race
Drives: Subaru Libird
There is a JDM version that had its pins rewired for USDM so that they are straight plug-and-play into USDM cars but the side reflectors don't light because they are still JDM housings. 2 things to can check if you have the rewired JDM version: 1) The turn signals light up amber. If they light up red, that's USDM. 2) They don't have any DOT/SAE markings on the plastic part of the housing that meets the weather sealing of your trunk lid. Only USDM housings have DOT/SAE markings.
If you conclude it is USDM, you might have some troubleshooting to do. The part is either defective or your Winjets are affecting it somehow. To eliminate the latter variable, might need to wire up your stock headlights (maybe your Winjets can stay bolted in as you swap connectors just to test). Or maybe a fuse in your car was blown?
Drives: Silver 2013 BRZ limited
if its USDM with the side light its straight up stamped DOT
if it isnt stamped its as simple as that. You have a JDM with USDM plug and play. IF it is stamped DOT your lights took a shit or something is wrong. If it isn't stamped, forget the DOT version, you won't ever get hassled for it and just run them without that side light. |
Yeah I have a usdm jdm version after all.. its all good ill rock them.. I thought it was my winjets causing it not to light up.. thanks everyone
#10 |
Drives: 86 ZN6
#11 |
Yeah I just notices that it does look cleaner with no lights. . Like it now lol.. yeah I saw the clear ones but I like the red lens on whiteout.. clear ones sure are nice.. I want to see it in person lol.. I like seening things in person before I buy lol
#12 |
Drives: FR-S 10 Series
Do the TOMS tail lights suffer from condensation like the OEM?
#13 |
SLO NO MO
#14 |
Drives: SWP Subaru BRZ
mine do not either. Perfectly condensation free
2013 SWP BRZ full STi Lip kit installed. Tons of other mods from interior to exterior. One of the cleanest BRZ's around in the midwest! Enjoy the build thread below. Full of pictures, exhaust clips, garage shots, and walk around video encasing its beauty. |
| Wtb TOMS Trunk lip | yugiooh | Want-To-Buy Requests | 1 | 08-19-2014 10:51 PM |
| Toms USDM Taillight installed photos | 86SPEED | Cosmetic Modification (Interior/Exterior/Lighting) | 22 | 05-21-2014 03:53 AM |
| FS: Helix Clear Sides with Bright White LEDs | Asphalt~86 | Exterior Parts (Aero, Lighting, Etc.) | 3 | 12-04-2013 10:08 PM |
| WTB Whiteout Passenger side fender or both sides | Minovsky | Canada Classifieds | 6 | 07-04-2013 08:52 PM |
| Seibon CF TA sides and KC rear lips | Do Boy | Cosmetic Modification (Interior/Exterior/Lighting) | 10 | 12-23-2012 08:28 AM |
