| BRZ First-Gen (2012+) — General Topics All discussions about the first-gen Subaru BRZ coupe |
Lando.Ricciardo.Hamilton.
Drives: 2014 SWP BRZ Limited (MT)
laggy/hesitant throttle response when upshifting?
Brand new owner here; I've only put ~150 miles on it since I took the keys. I'm noticing, at times, that the car is slow to respond when I get back on the throttle after upshifting. If and when this happens, the car will jerk into the power when it kicks in a split-second later.
Is this normal? It doesn't seem to happen as often when I am not shifting and getting on the gas in rapid succession (if I delay throttle input a split second), but that's kind of how I'm used to driving. I'm coming from a second generation Miata with a throttle cable, but I've also spent a lot of time in a third gen Miata with throttle-by-wire, and the shifts are fairly smooth. Thoughts? |
Trust me, I'm the Doctor
This is built-in. The drive-by-wire throttle has built-in dead space at the very top of the throttle. This results in a perception of a laggy throttle. It's intentional to account for bad habits by drivers who should know better.
This is a correctable defect.
Daily Driver: 2014 BRZ 6MT Limited ^GT5 Replay Photo Mode^ |
So what's the solution, if any? Do I just give up on getting on the gas quick and hard, post upshift?
#4 | |
The factory tune can use work anyways on stock exhaust and intake to simply run better. I'm in the process of having that done to my BRZ right now and it's resulting in noticable (if subtle) improvements in driveability, shift smoothness, top end torque and other niceties, in addition to a noticeable (and not so subtle) improvement in fuel economy. Also, if you get better tires, that could help too, as you will simply have better grip to grab the road better when you apply power to the wheels.
| The Following User Says Thank You to SirBrass For This Useful Post: | Formula Vee (02-11-2014) |
Drives: 2013 Scion FR-S 10 Series MT
Mods: K&N Air Filter - Open Flash Tablet (Stage 1 v1.55) - more to come!
| The Following User Says Thank You to Hanni_0176 For This Useful Post: | Formula Vee (02-11-2014) |
#6 | ||
Drives: 2013 BRZ Ltd. MT
I understand. This might "help":
http://www.ft86club.com/forums/showp...5&postcount=39 I agree about the NC Miata; we traded in our 2006 for the BRZ. The Miata was "normal," just another normal-shifting car like any other. But the BRZ? It'll leave you wondering, "Is there something wrong with this car, or is it ME?!" ![]() I have frequently thought that all these youngsters first learning to drive a manual transmission on the Twins ... well they're set for life, and will never have trouble again on any new car after learning on the BRZ/FR-S!
| The Following User Says Thank You to Porsche For This Useful Post: | Formula Vee (03-25-2014) |
It's just the clutch release height, honestly. I came from a WRX and STI, and my first time test driving a BRZ I had zero trouble shifting. It was just a high releasing clutch. That's totally fixable, though, so no worries.
This is actually a much easier car to shift than any other manual I've owned or driven. As far as a hesitant throttle, I tried the pedal trick and it worked!
#10 |
Drives: 2013 Whiteout FRS
What exactly is that pedal trick supposed to do though? Is it like the other "pedal dance" that puts the car into some sort of diagnostic mode?
#11 |
Drives: 2003 S2000, 2008 Fit
The WRX and STi also use drive-by-wire right?
There might not be much difference there - but if you go from an older car (say, early 2000s) to a recent car, it might be more noticeable. Would a lightened crank pulley help a bit? It is supposed to have quicker response, right? |
#12 |
I agree with this. The first 5% of throttle pedal travel is not very responsive, likely due to how the DBW is programmed. It's noticeable if you're coming from a traditional cable setup where the pedal feels linear. You eventually get used to it though.
2022 BRZ Build 2013 FR-S Build |
#13 | ||
What does this mean? First get a feel for the length of the clutch pedal stroke as you depress the pedal fully to the floor and then release it allowing it to come up fully to the top of the stroke. Get a sense of low LONG that stroke is. Now, depress the clutch pedal to the floor (engine running and car in 1st gear); then, slowly raise the clutch pedal to the point where the clutch just begins to engage; note WHERE in the pedal stroke that engagement point seems to be. I like it adjusted to a point around 1/3 to 1/2 way up in the pedal stroke. This is what affects your muscle memory; how much do you raise your left foot (most of us use our left foot on the clutch ) before encountering the point in the stroke where the clutch begins to engage. I try to see to it that our cars all have the engagement point occur around the same point, with the same amount of foot travel; this makes it easier to transition from one car to another.Adjusting this clutch pedal travel will also move the pedal "ride height," or where the pedal sits stationary in relation to the brake pedal. A lot of drivers like their clutch pedal to be level with their brake pedal. If you adjust this, it is CRITICALLY IMPORTANT to make certain of the following two points: (1) Ensure that there is approximately ½" of free play at the top of the clutch pedal stroke. It's hard to feel in my BRZ. Get an idea of how it feels BEFORE messing with the adjustment. This free play is essential to ensuring that the clutch disk is FULLY ENGAGED at the top of the stroke after you've taken your foot off the pedal. (2) Make certain that the clutch is FULLY DISENGAGED at the bottom of the pedal stroke. If the clutch is still dragging on the flywheel and putting some drive through to the gearbox via the input shaft … this will wreak havoc with the synchromesh in your gearbox. So, if you go too far with this pedal adjustment, your clutch life may suffer, or your gearbox life may suffer. Either way, you'll be unhappy paying for the repairs down the road. When adjusted properly (see above), this pedal height adjustment does NOTHING to change the mechanical operation of the clutch itself. It does not change the throwout bearing, the pressure plate function, the clutch disk, or the flywheel function. The clutch disk seems to bite fairly quickly on this car, mine anyway, and perhaps this contributes to the awkwardness in executing smooth shifts. But, changing the clutch pedal ride height (and engagement point within the stroke) has NO EFFECT on the mechanical operation of the components when keeping it in spec. How could it? One might think that production variances would be small and that there would be no need to adjust this on a new car. I have not found this to be true on the new cars we have purchased over the decades. It's not unusual to find that I need to adjust our new car's clutch pedal ride height to get what I prefer. Just remember, if you do this, to keep it within spec: ½" free play at the top and fully disengaged at the bottom. There's usually some room to play with within those limits, and I can find an engagement point that falls where I prefer it and which closely matches my other cars while keeping it in spec. Ergonomics are important. I dislike a clutch that engages high in the pedal stroke; I find it awkward to drive. Your mileage may vary, of course. Quote:
No, the "pedal dance" is entirely unrelated to what we're concerned with above. The pedal dance simply defeats some of the electronic nannies for stability control, etc. It does not alter the nature of the function of the components, it just TURNS THEM OFF. It turns off EBD, which still leaves me scratching my head about the advisability of doing it. There does not appear to be a clear consensus of opinion about doing the pedal dance; some say it solves their problems, while others say it creates worse problems. This is largely competition oriented and would not apply to most street driving for most drivers. But, do read about it just so you're better informed and know what is possible, as the day may come when it may offer a possible solution to some difficulty you're experiencing. I hope this has made sense to you and others, and has been helpful.
#14 | |
Very informative post Porsche, but I was actually asking about this when I said "pedal trick."
| Throttle Response | CamryDS | Northern California | 27 | 03-31-2015 03:35 AM |
| poor throttle response | Djen | Engine, Exhaust, Transmission | 21 | 06-14-2014 01:22 AM |
| Throttle response delay | jay07631 | Engine, Exhaust, Transmission | 12 | 07-09-2013 09:41 PM |
| Does the throttle response improve? | pr086 | Scion FR-S / Toyota 86 GT86 General Forum | 36 | 12-01-2012 01:06 PM |
| How's the throttle response? | SFTiofoso | Scion FR-S / Toyota 86 GT86 General Forum | 9 | 08-14-2012 11:50 AM |
