Old 02-10-2014, 12:57 PM   #1
TallTerror13
TallTerror13's Avatar
Drives: 2014 DGM BRZ & 2015 WRB WRX
DIY: LED Fog lights BRZ Limited
I changed the fog lights on my BRZ to LED's to better match the color of the HID's.
To get to the fog lights you need to remove the plastic rivets in the wheel well. There are 3 in the wheel well and one underneath.
Once you have the rivets out, you can reach right in and unclip the bulb. The new bulb that I went with is a 5w 12 LED Cree bulb off of ebay (search "2x H16 5202 5201 9009 CREE +12-SMD 5050 LED 5W White Fog Daytime Running Lights" )
You will have to trim the plastic on the bulb back in 5 places, 4 outside and 1 inside in order to make it fit into the OEM housing. A razor blade will work perfectly.
Once you trim the bulb and pop it back into the housing, just put all of your rivets back into place and enjoy!
The color is a lot better than the yellowish light from before, its not an exact match but at night they look a lot better! The light output is dim with the LED's, but the HID's make up for that! Here is a comparison...
TallTerror13 is offline   Reply With Quote
Old 02-10-2014, 02:43 PM   #2
Deathalo
Drives: 2013 WR Blue Limited Manual BRZ
Good lord clean your wheel wells!
Deathalo is offline   Reply With Quote
Old 02-10-2014, 02:45 PM   #3
TallTerror13
Hahaha! Sorry, we just got over a foot of snow and it hasn't been above freezing yet! The car was clean when I did the install, just not when I took the pic.
Sent from my DROID RAZR using Tapatalk
Old 02-10-2014, 02:52 PM   #4
Deathalo
Got it, aren't there some LED foglights that don't need any modifications? Just plug and play?
Old 02-10-2014, 02:56 PM   #5
TallTerror13
From what I understand there are 2 ways of a h16 bulb setup, the inside tab is on the other side. Trimming those tabs wasn't that bad and doesn't make a difference.
Old 02-10-2014, 03:01 PM   #6
TallTerror13
This is the stock bulb base...
The tabs on the inside top and bottom fit, the one on the right is what the led had in a different location. The outside tabs aren't even needed, but the led had them in different locations as well. It still has the clips that lock the bulb on and the 3 inside to make sure its in the proper location.
Enkei NT03 18x9.5 +40 5x100 Silver, Hyper Black, Gold Evasive Motorsports Wheels and Tires 92 09-10-2015 09:38 PM
Limited BRZ fog lights BMWDavid Cosmetic Modification (Interior/Exterior/Lighting) 42 07-22-2015 11:35 PM
FT NJ: BRZ Limited OEM Fog Lights for Premium non-fog wawawoowee Exterior Parts (Aero, Lighting, Etc.) 10 02-02-2014 09:53 PM
DOT/SAE Approved TOM'S Special Limited Edition Tail Lights switchlanez Cosmetic Modification (Interior/Exterior/Lighting) 82 10-07-2013 04:04 AM
Fog Lights - Premium vs Limited Dionysus BRZ First-Gen (2012+) — General Topics 44 03-17-2012 04:15 AM
