Old 02-07-2014, 02:01 PM   #1
MTCRX
MTCRX's Avatar
Drives: Whiteout FRS- autocross ready
open end lug nuts for stock rims
I will be putting ARP extended studs on my FRS this spring for autcross with RPF1 wheels. I have lug nuts for the RPF wheels but in the fall I will need to put the stock rims on with snow tires. Does anyone know which open end lug nuts work with the stock rims?
MTCRX is offline   Reply With Quote
Old 02-07-2014, 02:08 PM   #2
Any conical seat open-ended lugs will work.
CSG lugnuts would be an excellent candidate, if you don't already have a set.
/shameless promotion
MTCRX (02-07-2014), Scooby South (02-07-2014)
Old 02-07-2014, 05:31 PM   #3
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
12x1.25mm lugs, specifically.
And what Mike said.
/shameful promotion
-alex
Old 02-08-2014, 10:24 PM   #4
48Spoons
Drives: Ultramarine FR-S
Do the 86 stock wheels just use the same type of lug as after market wheels? I ask due to this line from your site:
Warning
These lug nuts are designed with tapered bottoms for aftermarket wheels. Do not use these lug nuts for your factory OEM wheels.
Sorry if I sound like a douche, but genuinely curious.
48Spoons is offline   Reply With Quote
Old 02-08-2014, 11:56 PM   #5
Ranatsu
Cone basher
Drives: 2017 Subaru BRZ Series.Yellow
Subaru's lug nuts are a 60 degree conical taper which is the same as the after market options. The only problem you may have is some wheels have difficulty fitting a 19mm socket.
Ranatsu is offline   Reply With Quote
The Following User Says Thank You to Ranatsu For This Useful Post:
48Spoons (02-09-2014)
Muteki Extended Open Ended Lug Nuts - Neo Chrome tlinspired830 Wheels and Tires 9 03-18-2014 09:34 PM
Selling Muteki Lug Nuts - Purple Open Ended KamakazeProject Wheels and Tires 6 02-03-2014 06:57 PM
Jcm open end forged lug nuts 12x1.25 night0 Wheels and Tires 0 10-01-2013 09:07 PM
FS: Muteki SR48 open extended lug nuts - SOLD ayau Wheels and Tires 0 07-17-2013 11:35 PM
