Old 02-06-2014, 08:48 PM   #1
rhythmM
rhythmM's Avatar
Drives: 2014 Subaru BRZ Limited MT - White
BRZ Limited OEM HID, brightness?
So I have a BRZ limited and I know it comes with factory HID headlights already... But to me it still doesn't seem as bright as others. My friends 92' civic has a 35w HID kit and it's quite brighter than the BRZ's lights.
Does anyone know if there is a reason for that? Or maybe I'm just imagining things...
Aside from that, is it possible to upgrade the OEM HID ballast to an aftermarket 55watt kit? Also does anyone know where the OEM ballast is located at?
Thanks in advance.
Phantom Super Charged - 2014 BRZ
rhythmM is offline   Reply With Quote
Old 02-06-2014, 09:17 PM   #2
Krispeee
Brightness, in my opinion, is subjective as there are numerous factors that play into usable light.
Is your friend's Civic retrofitted with HID projectors? Without them, light will disperse all over the place, causing them to seem like they're brighter. Projectors will create a light cut off, allowing the light to be more usable (aimed at the road) instead of the treeline above.
If you look at a car head on w/o projectors, they will definitely seem brighter than they really are from the driver's point of view.
Another thing to as what the Kelvin value or color temperature that your friend is running. I too have a BRZ Limited and I'm not sure what the Kelvin temp is, but it looks close to 4000K. If your friend is running anything above 5000K to 6000K, it may seem a bit brighter if you looked at them head on.
Hope that helps.
Krispeee is offline   Reply With Quote
Old 02-06-2014, 09:19 PM   #3
chenshuo
chenshuo's Avatar
Drives: WRB BRZ
i've noticed that too. My BRZ HID doesn't look bright.
chenshuo is offline   Reply With Quote
Old 02-06-2014, 09:19 PM   #4
mabviper
Drives: WRB BRZ
Does your friend have a projector lens setup for his HID? If not, then it would appear a lot brighter than the BRZ's HIDs. That's just because his light is being scattered everywhere, blinding everybody on the road. BRZs have projector lenses for its HIDs. It's a focused plane of light. It's really bright but at eye level, it will not blind you.
IMO, the BRZs lights are really bright and projects really far down the road. That's the most important part.
mabviper is offline   Reply With Quote
Old 02-06-2014, 09:41 PM   #5
BRZNutt
BRZNutt's Avatar
Drives: 2014 DGM Subaru Impreza 2.0i 5 Door
BRZ stock HID bulbs are 4300K. This is what most OEMs use because it is close to what the sun emits and therefore theoretically provides the best output for the human eye. Don't judge how bright your lights are by looking at them, but rather how they look from the drivers seat. They are the first HIDs that I have had on a car and I will not go back to halogen.
2016 World Rally Blue Subaru WRX Limited
2013 Satin White Pearl Subaru BRZ Limited 6 MT (Sold)
BRZNutt is offline   Reply With Quote
Old 02-06-2014, 09:44 PM   #6
woode
Boosted Member
woode's Avatar
Drives: 2013 Subaru BRZ
Send a message via MSN to woode
I think the OEM BRZ headlights are great.. love the look and the brightness.
2013 Subaru BRZ LTD 6MT DGM
2014 Subaru XV Crosstrek Hybrid TRG PG
2011 Honda CBR1000RR
2010 Subaru Impreza WRX PRM SSM
woode is offline   Reply With Quote
Old 02-06-2014, 09:46 PM   #7
JS + BRZ
Drives: 2010 MS3
Heard our OEM HID unit is the same thing as RX350 unit.
It's bright as hell imo.
You probably think your friend's is brighter because HID can blind your eyes without projector housing.
JS + BRZ is offline   Reply With Quote
The Following User Says Thank You to JS + BRZ For This Useful Post:
illmatic (02-06-2014)
Old 02-06-2014, 09:49 PM   #8
rhythmM
rhythmM's Avatar
Hope that helps.
I don't believe he has projectors. Just staring and comparing the two focal points between the BRZ and civic. His focal point just seems quite a deal brighter. I think he is running 6000k or 8000k.
Correct me if I'm wrong but, the higher you go up on the kelvin range, doesn't that appear to diminish the "light output?"
Old 02-06-2014, 09:55 PM   #9
woode
Boosted Member
woode's Avatar
Yes.
Ideal is 4200-4500k range. 5000k is white which some like.. past that you start getting into the dumb blues and stuff that people seem to think is cool, despite having reduced output.
If he doesn't have projectors, it is definitely not actually brighter. It just scatters light everywhere and appears brighter. The usable light is far less if you had them side by side. And the obnoxious-to-other-drivers factor on his will be much higher.
The Following User Says Thank You to woode For This Useful Post:
SirBrass (02-06-2014)
Old 02-06-2014, 10:06 PM   #10
rhythmM
rhythmM's Avatar
Originally Posted by woode View Post
Yes.
Makes sense.
Do you happen to know if it's possible to upgrade the our HIDs to 55w?
Old 02-06-2014, 10:18 PM   #11
soundman98
ProCrastinationConsultant
soundman98's Avatar
not really worth it. at 55w, you're going to start risking damage to other components if you're not careful..
it's really just best to just stop comparing apples to cassette tapes...
Old 02-06-2014, 10:51 PM   #12
sshole
But cassette tapes are so delicious when you unwind them a little bit...
sshole is offline   Reply With Quote
The Following User Says Thank You to sshole For This Useful Post:
FnFast (02-07-2014)
Old 02-06-2014, 11:16 PM   #13
KONVERTER
KONVERTER's Avatar
you are comparing HID's in a projector housing to HID's in a housing made for standard bulbs that shoot light everywhere...
KONVERTER is offline   Reply With Quote
Old 02-06-2014, 11:20 PM   #14
soundman98
soundman98's Avatar
i've always preferred the taste of beta tapes over cassette tapes, but 'different strokes' i guess...
FRS/BRZ Full Interior LED Kit! Choose your brightness! See Installed Comparison Pics! Diode Dynamics Interior Parts (Incl. Lighting) 243 08-29-2018 01:01 PM
>>> 5000k & 6000k White Reverse/Back-up LED Lights - FREE SHIPPING and 3 yr warranty! KI_ZN6 Exterior Parts - Lighting 870 02-19-2016 12:04 AM
Group Buy Limited Limited Limited Edition 57Xtremes in KY color vividracing Groupbuys 0 10-14-2013 08:22 PM
Head Unit Brightness ShoNUFF Electronics | Audio | NAV | Infotainment 3 09-10-2013 07:33 AM
BRZ Limited for sale; limited; 6 spd; WRB dabguy Cars for Sale/Trade 1 11-04-2012 11:13 PM
