| BRZ First-Gen (2012+) — General Topics All discussions about the first-gen Subaru BRZ coupe |
I dream of BRZ
Drives: Prospective BRZ owner.
Can the 250 hp version of the fa20 be put in the BRZ? I am a noob and so I ask although I tend to think that the obvious answer is yes.
If so, is that something many people would be doing rather than picking up after-market parts? What about you? Why or why not? If they put that motor in the 2016 Brz would you rather buy that or buy a 2014 brz and mod it via aftermarket FI for more than 250 hp. Thanks. |
Drives: 2006 Cayman S, 2007 Outback 2.5i
If I remember right, isn't the turbo in the FXT bottom mounted? If so, there wouldn't be room in the BRZ...
| The Following User Says Thank You to chrisl For This Useful Post: | strat61caster (01-27-2014) |
Pros: Boxer engine, Subaru built, same basic mounting points
Cons: It's a new engine in a new car, costs waaay more money than other options (aftermarket FI, more available engine like LS or EJ). The piping doesn't work out with the space in the Toyobaru, you would have to replumb the whole thing, might as well do an aftermarket turbo for the amount of work required, the plumbing has already been worked out. Subaru Direct Injection vs. Toyota D4-S, not sure which ECU you would use not to mention the rest of the harness for all the Toyobaru's systems. Same block should have the same transmission mounts but that's not guaranteed considering the Forrester is CVT exclusive I believe Cons #1 & 2 are usually enough to dissuade most. If you want more power swap in a V8 or something cheap, simple, and available. If you want a turbo just go aftermarket bolt on with a tune. Both are immensely cheaper than getting Subaru's FA20T. http://www.ft86club.com/forums/showthread.php?t=47004 Edit: Can't wait for these threads asking about the WRX's 268 hp motor
Drives: 2005 Toyota Camry
#5 | |
Trust me, I'm the Doctor
Now, if you have to replace a blown block and don't want to go built-motor yet, and already have a turbo kit, then if you can pick up one of these for about the same price as a fully built stock FA20 (block and headers).... THEN it'd make sense. Otherwise, nope.
Daily Driver: 2014 BRZ 6MT Limited ^GT5 Replay Photo Mode^ |
#6 | |
(Admittedly, it would still probably be not worth swapping the engine, since that's only one of several problems with the prospect, but it's still fun to think about...) |
#7 | |
It was already asked elsewhere (not sure if it was on ft86club or on iwsti), and that was the conclusion. Remember, compared to other subies, the twins are ridiculously low to the ground in general, and the engines in particular.
Drives: 2013 Subaru BRZ
So we would have to basically relocate the turbo and find a way for the A960E transmission that the Brz uses to work with the engine right?
I’m kinda in this scenario with my 13’Brz. Blew the motor, been trying to save 3.5k for a used stock Brz motor but some forester motors are going for 1500.
#10 | |
Drives: Crapcan
2. How are you going to get the ECU to run it? I could be done, but it would be a nightmare far beyond the average garage mechanic. 3. You are replying to a thread from 2014, pretty sure nobody has bothered with it beyond talking about it.
#11 |
Airborne at your service
Drives: '17 BRZ Series.Yellow
Just get another FA20 or go big and do a proper LS- or K-swap
#12 |
Drives: 2013 BRZ Sport-Tech
If he can't afford a stock FA20 how is he going to be able to afford to "go big"?
Sorry OP, but I think you're stuck saving up for a replacement BRZ/twin motor. With all the various things you'd have to come up with custom solutions to the Forester engine would wind up costing more. |
#13 | |
#14 |
How do I shift?
Drives: '13 GBS BRZ
| The Following User Says Thank You to carsebuco For This Useful Post: | CrowsFeast (10-28-2021) |
| OEM Oil cooler from the 2.0 DIT Forester | Kostamojen | Engine, Exhaust, Transmission | 119 | 09-10-2019 05:28 AM |
| BRZ wheels on Forester XT | sea otter 99 | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 19 | 01-02-2017 06:56 PM |
| Any chance Dealer can retro-fit Forester XT's engine to BRZ? | qqzj | BRZ First-Gen (2012+) — General Topics | 18 | 12-21-2013 12:02 AM |
| 2014 Forester key fob - nicer than BRZ | Turbowned | Cosmetic Modification (Interior/Exterior/Lighting) | 3 | 04-17-2013 03:35 PM |
| OEM Forester All Weather floormats | Laika | Cosmetic Modification (Interior/Exterior/Lighting) | 2 | 01-14-2013 09:19 PM |
