Drives: Scion Fr-s 2013
10k miles
I am finally about to hit 10k miles on my car. What are some major things i should check on my car and get done on my car? I do know i need an oil change, at 11k, but ima get it done at 10k
Nothing should require replacement or overhaul after only 10k miles, she's still young. You can always perform a visual and hands on inspection under the car and throughout the engine bay to look for issues suck as loose bolts, torn CV boots, brake pad wear, broken wire ties, chafed/worn wiring, belt wear, rust, oil residue or leaks, fluid levels, etc.
You could look at the maintenance schedule to see what might need attention. If you're really hard on the car or track it, you should have a more frequent inspection and maintenance schedule of your own. |
Drives: 2019 BMW ///M4
10K Miles....
Perform an Oil Change and Tire Rotation. Inspect and top off/replace if necessary: Brake fluid Coolant Washer Fluid Belts Hoses Tire wear Wiper blades If brake fluid is low, it can either indicate worn out pads or a brake fluid leak. Recommendations but not required: Tire Balance and an alignment. |
| How many miles on your car? | Sitha@ft86club | Scion FR-S / Toyota 86 GT86 General Forum | 333 | 12-30-2015 05:49 PM |
| 86 Miles | EAGLE5 | Scion FR-S / Toyota 86 GT86 General Forum | 7 | 03-11-2013 11:14 PM |
| BRZ/FRS over 5k miles | foxhu | BRZ First-Gen (2012+) — General Topics | 51 | 02-17-2013 10:39 AM |
| How many miles are on your FR-S? | Jayde | Scion FR-S / Toyota 86 GT86 General Forum | 47 | 11-25-2012 11:24 PM |
| Only 951 miles to go! | TRBO2NR | Scion FR-S / Toyota 86 GT86 General Forum | 25 | 10-26-2012 12:34 PM |
