Old 01-23-2014, 06:20 PM   #1
Luckrider
My Other Ride's a Jeep
Luckrider's Avatar
Drives: 2013 BRZ Limited
10° This week. e85 or 93
I've have run 4 tanks of e85 with Shiv's OFT tunes. I need to fill up after work and am trying to decide if I should stick with e85 or go back to 93. With the sub 10° temps, it takes at least two cranks to get fire in the morning. I'm getting about 20mpg but paying $3.18 as opposed to ~26mpg and $3.68 per gallon. I can't make up my mind.
Here is a bunch of my logs: http://datazap.me/u/luckrider
Luckrider is offline   Reply With Quote
Old 01-23-2014, 06:32 PM   #2
1086
1086's Avatar
Drives: UM86 - 6MT
Honestly - I have heard it is good to cycle your fuels i.e. For every 3-4 tanks of E85, fill up 50% or 100% of your tank with 91/93. Perhaps it is not necessary but I heard it is good practice.
1086 is offline   Reply With Quote
Old 01-23-2014, 06:48 PM   #3
reeves
I finally had to give up E85 when the temps dropped near freezing over night.. Cranking the car for 5-10min in the icy morning just becoming too much of a pain. I'll go back to it once the temps get warmer.
reeves is offline   Reply With Quote
Old 01-23-2014, 06:50 PM   #4
Luckrider
Luckrider's Avatar
Cold starts above 15° seem to be just fine. It is the below 10° that makes it stumbling starting with a cold engine. I think my station is pumping ~e70.
Old 01-23-2014, 06:56 PM   #5
reeves
You're talking about 15 Celcius I assume? In which I totally agree.. that's where I'm starting to see the cut-off for long crankings in the mornings too before the engine fires up. Makes me wonder how the factory Flex-fuel cars (my friend's Tundra, for example) start up so easily even when temps are freezing? If they can do it, I'm hopeful a good tuner will be able to figure it out eventually.
Old 01-23-2014, 07:00 PM   #6
Sterling Doc
Drives: 2002 911 Targa
It's -2 right now. About to head out to start up the BRZ. Wish me luck! This should be a new record, but it has started on the first crank at 0 before (did stall once). Winter blend of E85 makes the difference. Fuel trims are still minimal, runs great.
Sterling Doc is offline   Reply With Quote
Old 01-23-2014, 07:02 PM   #7
Luckrider
Luckrider's Avatar
Fahrenheit. My guess is that the flex fuel cars adjust their IPW with a special compensation table dependent on the e%. It has been figured out in our cars and I have a modified tune with different cranking Injector Pulse Width table values. I just haven't used it because the e85 tune gets better the longer you run it unflashed (because the learning of the computer us pretty good). I wasn't having starting issues so I didn't change anything.
Old 01-23-2014, 07:11 PM   #8
reeves
You're talking Farenheit? Man, mine's won't even crank for ~10min if it's under 30 F degrees! I do miss filling up with the cheaper E85 price too. I got Ecutek so I gotta find someone who knows how to adjust the cold cranking for me.
Old 01-23-2014, 07:12 PM   #9
Luckrider
Luckrider's Avatar
@reeves, What tuning solution are you using?
Old 01-23-2014, 07:18 PM   #10
reeves
Ecutek.. they allow you to modify your own tunes now, but I gotta dish out an additional $300 to get that upgrade. I'd rather just find someone who knows what they're doing to try & adjust it for me. I'm happy with my E85 tune, just not the cold cranking part.
Old 01-23-2014, 07:19 PM   #11
steve99
Shiv reckons his tune is good for between E60 and E85, maybe you could do a Mix of E85/93 to drop your E content to around 60-70 for easier starts.
Old 01-23-2014, 07:27 PM   #12
Luckrider
Luckrider's Avatar
I thought you could actually tune the car yourself with the free software. I thought the upgrade was for multiple maps, custom maps, table comparisons and some other stuff that isn't needed to actually tune the car from scratch yourself. @jamesm can probably give better insight to that. With the OFT and RomRaider, I can edit the Cranking tables myself.
Old 01-23-2014, 07:33 PM   #13
Carlitoz3
Carlitoz3's Avatar
Drives: 2013 MT Asphalt FRS
I can switch between premium and e85 as freely as I like?
Carlitoz3 is offline   Reply With Quote
Old 01-23-2014, 07:39 PM   #14
Luckrider
Luckrider's Avatar
With a tuning solution like the OFT or ECUtek, you just flash a new map for the fuel you are running. For about $2,000, you can get ECUtek and the needed hardware to run a true FlexFuel setup.
I think I might just flash the modified 1.42b map I have and stick with the e85.
ONE FREAKING WEEK!!!! Xlr8 Scion FR-S / Toyota 86 GT86 General Forum 54 10-23-2013 04:29 PM
FR-S/BRZ Week – Exciting Week For Owners 86_Insider Scion FR-S / Toyota 86 GT86 General Forum 2 08-09-2013 06:38 PM
ETA = This week! VADER Scion FR-S / Toyota 86 GT86 General Forum 7 05-20-2012 06:18 PM
MY GF's FRS confirmed for last week of May or first week of June clayrush Scion FR-S / Toyota 86 GT86 General Forum 45 04-19-2012 04:45 PM
