Old 01-13-2014, 09:59 AM   #1
davidshu0327
Drives: Scion Frs
Good 5x114.3 conversion spacer?
WHat is a good a reputable 5x114.3 conversion spacer. I want to run wheels that are 5x114.3 and my friend says using adapters is a risk I have to take, therefore I wanna find out the opinions of the community on this forum. THANKS
davidshu0327 is offline   Reply With Quote
Old 01-13-2014, 10:20 AM   #2
Figo
Figo's Avatar
Drives: Vortech Supercharged FR-S
Megan Racing made hub conversion.
I would not run 5X100 to 5X114.3 spacers if I were you.
I'd rather lose by a mile because I built my own car,
than win by an inch because someone else built it for me.
Your car is your story, so don't let someone else write the book.
( White Tiger ) - FiGo's 車誌.
Figo is offline   Reply With Quote
Old 01-13-2014, 10:21 AM   #3
Muskokan
Drives: white Sport-tech
also interested in the price, pro/cons on these.
Muskokan is offline   Reply With Quote
Old 01-13-2014, 01:10 PM   #4
slicktop
Drives: 2013 Raven FRS 2JZ-GTE/V160 swapped
Adapters - Kics, if you're just cruising the street, you're fine.
Hub conversion - Hardrace or Megan's (Assumption: hardrace copy). You'll need a new brake setup if you do a hub conversion or redrill your stock rotors for 5x114.3
slicktop is offline   Reply With Quote
Old 01-13-2014, 05:11 PM   #5
zooki
Drives: waiting on a 2021...
I have some I ordered from Circuit Motorsports. My car is a daily driver, no track time. I've had them on for a few thousand miles and no problems. I'm going to put the car back on my lift and recheck the torque on the lugs holding the adapters to the car in the next couple of days.
2016 4Runner Tail edition
2020 Camry 2020 RAV4
2013 Chevy 3500 4x4 Duramax
1999 Ford F250 Powerstroke, the tow rig
1969 Mustang, the fast car....(:
zooki is offline   Reply With Quote
Old 01-13-2014, 06:16 PM   #6
Touge Factory
Touge Factory's Avatar
Drives: ZN6
Send a message via AIM to Touge Factory
We are using Kics 5x100 to 5x114 conversion spacers on our car.
Just like any other components on the car, just check them regularly. Make sure they are torqued to proper specs.
You shouldn't have any problems.
Click here for more info
Touge Factory is offline   Reply With Quote
Old 01-13-2014, 06:24 PM   #7
xia
Drives: 1995 Supra TT & 2013 FRS
Does this change the offset?
xia is offline   Reply With Quote
Old 01-13-2014, 06:49 PM   #8
Touge Factory
Drives: ZN6
Yes they have two options:
10mm and 15mm.
Project Kics 11mm or 15mm P.C.D. Conversion Spacer - 5x100 to 5x114.3 (12x1.25mm) Evasive Motorsports Wheels and Tires 31 06-13-2015 08:09 PM
Project Kics 10mm 5x100 to 5x114.3 Conversion Spacer Hubcentric deedz Wheels and Tires 12 05-22-2013 04:18 AM
25mm conversion spacer with 5mm spacer = safe or unsafe? deedz Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 1 05-05-2013 11:59 AM
Project Kics 15mm P.C.D. Conversion Spacer Mcdj18 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 13 01-07-2013 08:36 PM
wheel spacer to 5x114 derka-derka AUSTRALIA 12 07-02-2012 11:27 PM
