Old 01-12-2014, 07:37 AM   #1
Chimera
Drives: FRS
Helix side markers water entry
Seems to be a few folks mentioning that these let in water. I got a set of these a week ago to install. Haven't yet. I am planning to use a silicon based adhesive seal when I do. Here's some questions to those who have had these installed and had issues (or not for that matter).
Any ideas on how the water is entering the enclosure? I would assume that it is along the lights mount, as the sides appear well sealed on my new ones.
I was planning on sealing the entire back edge and the light mount itself, and possibly looking for a rubber gasket ring if one will fit without obstruction. Anyone who has done this is there room for that at all?
Thanks.
Old 01-12-2014, 12:03 PM   #2
nyfries
Drives: 14 FRS Whiteout
Had a couple of really raining days the past few days and yes there is now water inside them side markers. The worst part is the upper right corner, the corner closest to the wheels. The corner is now filled with wet dirt and looks quite unsightly. I don't know if there is enough space to seal it. Its quite a tight fit, so much so that it nick the painted on my passenger side when i was installing it.
nyfries is offline   Reply With Quote
Old 01-19-2014, 12:00 PM   #3
Chimera
Drives: FRS
SO I picked up some Momentive RTV108 that I'll be applying to the seals all the way around the side markers, and letting cure for 2 days. I live in Atlanta, where it rains.. a lot. so I think I'll know before to long whether it was effective in handling the water entry issues.
Still looking for anyone else's feedback if anyone has anything to share?
thanks
Old 01-19-2014, 01:34 PM   #4
Chimera
Drives: FRS
Photo after sealing edges.
Old 02-07-2014, 04:45 PM   #5
Chimera
Drives: FRS
update:
swapping smoked for clear:
its rained a snowed a few times, no water entry at all, just some dirt of the back of the adhesive sealer
Old 02-08-2014, 12:35 AM   #6
lpresley
lpresley's Avatar
Drives: Dark Gray Metallic BRZ
That looks like the route I'll be going, my left one is full of moisture, I'm sure a little sealant would make it a quick fix, surely there's no moisture getting in from the back
lpresley is offline   Reply With Quote
Old 02-10-2014, 10:07 PM   #7
chas3wba0
chas3wba0's Avatar
Drives: Yes
Originally Posted by Chimera View Post
update:
My left-side clear got all damp inside after a few days of rain... very unimpressed with the quality of these. I went the same route in sealing the edges but with Loctite Waterproof Stik N' Seal; we'll see how that goes...
"If thy pleaſure be in Underſteere, thou art Weird." - Distraxi
Old 02-10-2014, 11:00 PM   #8
Chimera
Drives: FRS
I'm very interested to hear about how it works out from someone who's actually had the issue.
I preempted the issue, and therefore am not a solid example.. as on an off chance mine may never have had the issue in the first place.
Old 02-11-2014, 06:16 PM   #9
chas3wba0
chas3wba0's Avatar
Drives: Yes
I bet you would have seen leakage in at least one of them, at least under extreme conditions. Best test on the fix would be to take a hose and spray directly at side marker under the fender lining
Old 02-19-2014, 12:26 AM   #10
chas3wba0
chas3wba0's Avatar
Drives: Yes
An update: Since sealing the edges, I have driven through rain and wet mud and even sprayed water directly at the side marker piece while washing my car, and so far no significant water entry. One side had a slight mist of fog along the inner edge, but it evaporated pretty quick. Not gonna pursue it further for now.
Old 03-22-2014, 10:47 AM   #11
JR007
JR007's Avatar
Drives: Ultramarine FR-S
Did you buy the Helix ones?
JR007 is offline   Reply With Quote
Old 03-22-2014, 12:24 PM   #12
Snowblind
It's easier to not be cheap and just buy the OEM ones. They come water sealed from the factory.
Old 03-22-2014, 12:38 PM   #13
KI_ZN6
KI_ZN6's Avatar
Thumbs up
I agree, alot of our customers purchased our OEM Genuine Japan-made Clear Side Markers and they are problem-free.
KI_ZN6 is offline   Reply With Quote
Old 03-22-2014, 01:15 PM   #14
JustBoostin
Drives: Asphalt FR-S 6MT
I would have opted for the OEM clears if i didn't want smoked ones! Haha
JustBoostin is offline   Reply With Quote
*NEW JDM Style Side Markers Helix Clear/Smoked/Dark +$100 STORE CREDIT + FREE BULBS!* Vicious LED Groupbuys 721 05-15-2014 07:42 PM
*GB Helix Side Markers $55 Clear/Smoked + FREE LEDs Massdrop Groupbuys 91 10-12-2013 12:20 PM
*** Helix JDM Style Clear/Smoke Side Markers -- FREE LED Bulbs & 86 Piston Plate 86_ZN6 Exterior Parts - Lighting 87 09-14-2013 11:53 PM
Helix Smoked Side Markers from 86_ZN6 neil125 Cosmetic Modification (Interior/Exterior/Lighting) 7 09-06-2013 02:52 PM
FS Helix JDM Clear Side Markers & HID Conversion Kit gpellis87 Exterior Parts (Aero, Lighting, Etc.) 5 06-19-2013 06:38 PM
