Old 01-11-2014, 12:57 AM   #1
stugray
Drives: 2013 GBS BRZ Limited
Cant make a simple log work with my OP2.0 standalone
I cannot get the following simple log to work on the BRZ.
here is the logcfg.txt:
type=adc
paramname=battvolts
paramid=16 ; OBD pin
scalingrpn=x,0.001,* ; here we scale to volts
paramname=throtpos
paramid=8 ; OBD pin
;-------------triggers---------------
conditionrpn = battvolts,0.0,>
action = start
Here's the logcfg.out file:
001: type=adc
: name[type,8] value[adc,0,0.000000]
002: paramname=battvolts
: name[paramname,16] value[battvolts,0,0.000000]
003: paramid=16 ; OBD pin
: name[paramid,17] value[16,16,16.000000]
004: scalingrpn=x,0.001,* ; here we scale to volts
: name[scalingrpn,18] value[x,0.001,*,0,0.000000]
005: paramname=throtpos
: name[paramname,16] value[throtpos,0,0.000000]
006: paramid=8 ; OBD pin
: name[paramid,17] value[8,8,8.000000]
007: scalingrpn=x,0.001,* ; here we scale to volts
008: ;-------------triggers---------------
009: ;
010: conditionrpn = battvolts,0.0,>
: name[conditionrpn,48] value[battvolts,0.0,>,0,0.000000]
011: action = start
: name[action,49] value[start,0,0.000000]
--- log config dump ---
firmware version is: 1.14.4010
the following general options are set:
* interpolate missing samples
* zero sample count at start of each file
channel type: adc
param name: battvolts
param id: 0x00000010
scaling: x,0.001000,*
param name: throtpos
param id: 0x00000008
trigger action: start condition: battvolts,0.000000,>
--- storage info ---
log channels: 1
log parameters: 2
log stringlist: 29 chars
log floatlist: 2 floats
logging interval will be 1000000us
It just sits and does not log anything.
What am I doing wrong?
Anyone else want to try it and see if it works for you?
All I am trying to do is log the battery voltage and the voltage on pin 8 of the OBD connector (OEM8)
Old 01-11-2014, 04:37 AM   #2
ztan
Drives: Toyota 86
Refer to:
td-ds RAM parameters
http://www.ft86club.com/forums/showt...=47322&page=15
and Colby's sample mode 23 file at:
http://www.tactrix.com/downloads/ecu...ta_1444040.exe
The OP 2.0 needs this version of EcuFlash to update firmware to use mode 23
Logcfg.txt for what you wanted above:
Code:
type = obd
protocolid = 6 ; ISO15765
mode23txaddrwidth = 4        ; mode23 req format info
mode23txlenwidth = 1        ; mode23 req format info
mode23rxaddrwidth = 0        ; mode23 req format info
mode23uds = 1            ; lets OBD channels know you are using mode23 UDS
sortpids = 1            ; sort these PIDs by value to potentially make for fewer requests (=faster)
calcsampinterval = 1000        ; timing parameter - leave as is - will make default for release version
paramname = BattVolt
paramid = 0xFFF87C6C
isfloat = 1
paramname = Throttle
paramid =  0xFFF89030
isfloat = 1
conditionrpn = BattVolt,0,>
action = start
ztan is offline   Reply With Quote
Old 01-11-2014, 01:42 PM   #3
stugray
Thanks but I am trying to get JUST the ADC portion to work, because I want it to work on a car that has no OBD port.
I have a 71 racecar that I put a dummy OBD port in.
I want to log some analogs and some innovate (serial) data.
I could not get the innovate data to log, so I thought I'd try the analog only first.
It still wont log, so I thought I'd try the analog only on the BRZ to see if I was missing some pin in the OBD that is required. Nothing.
All of the examples online show that my logcfg.txt I posted above should work, but it doesnt.
I was hoping someone else would try my exact log file with their OP2.0 to see if it works for them.
I bought my OP2.0 used, so I am wondering if there is something wrong with it.
So far I have not gotten it to log anything.
II get the *.out file, so I know it is ingesting the logcfg, it just never outputs any kind of data.
Old 01-11-2014, 05:20 PM   #4
ztan
Drives: Toyota 86
So it is just the ADC portion of your openport that you want to test. Have you checked that OBD mode 0 and 23 work ok?
Old 01-11-2014, 06:51 PM   #5
stugray
No but that's why I was asking for a def for my 700C ROM over on the ROM Defs thread.
I might give it a try tonight with Td-d's suggestions.
Ems4 AEM Standalone? Scalzo Software Tuning 26 11-08-2013 02:42 AM
first standalone ECU? ElectronSpeed Engine, Exhaust, Transmission 14 03-16-2013 01:03 PM
DI pressure sensor calibration? - standalone ElectronSpeed Engine, Exhaust, Transmission 0 02-27-2013 11:38 PM
anyone make a similar or replica version of Work XD9? denverizzles Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 15 08-26-2012 02:53 PM
Not working... well I'll make it work ichitaka05 Other Vehicles & General Automotive Discussions 12 11-11-2011 10:42 PM
