Old 01-08-2014, 02:15 PM   #1
r1concepts
r1concepts's Avatar
Stoptech Racing Brake Pads now available!
We now offer Stoptech Racing Brake pads to users here on the forum. Stoptech offers 4 different compounds (SR30, SR32, SR33, SR34) and each compound has it's own characteristics. These pads only work with Stoptech BBK's! PM me for pricing!
SR30 Compound
-Medium to low friction levels with linear torque curve with rising temperature
-Extreme high temperature fade resistance
-Excellent modulation and release characteristics
-Repeatable performance
-For Touring Car rear applications and others requiring lower torque
SR32 Compound
-Similar friction levels to the SR34 Compound
-Linear torque curve with temperature rise with excellent release characteristics
-Superb abraded disc wear
-Maximum high-temperature stability
-For medium to high horsepower applications that require higher friction levels
SR33 Compound
-Slight reduction in torque compared to SR34 Compound
-Excellent pedal modulation for applications requiring a medium friction level
-Flat torque curve with temperature rise
-Extreme fade resistance
-Great for rear applications that require less friction but same level of control as SR34 Compound
SR34 Compound
-Superior pedal feel and modulation characteristics
-Formulated for high initial bite
-Slight torque rise with temperature
-Extremely low pad and abrade disc wear
-All purpose pad for high grip, high power application
Here's a link to their site:
http://www.stoptech.com/racing/racin...ing-brake-pads
r1concepts is offline   Reply With Quote
Old 01-08-2014, 03:01 PM   #2
What are the temperature ratings and mu curves for each compound? What type of pads (materials in the pad material) are these? Compressibility? Comparable pads for each compound, since they list no specs?
Old 01-08-2014, 07:55 PM   #3
r1concepts
r1concepts's Avatar
Being that these just have been released, Stoptech has no technical specs of each pad compound and temperature rating. Stoptech does state on the link given that their metallic compounds are blended with "carbon and graphite particles". This is all I know as of right now. Once Stoptech releases the technical specs of each pad compound, I'll definitely let you guys know and give you an update. As of right now, all the info about these pads are on their site (link given).
THESE PADS ONLY WORK ON STOPTECH CALIPERS!
2005 STI Brembos Powder Coated, Hawk HPS Pads, Stoptech Rotors and Braided Brake Line Jamifra Brakes, Suspension, Chassis 10 10-29-2013 10:31 AM
LPI Racing GB on Brake Pads MyRx Northern California 4 08-22-2013 01:02 PM
DBA Rotors & StopTech Brake Pads IN STOCK, FREE SHIPPING Import Dynamics Brakes, Suspension, Chassis 26 04-30-2013 08:05 PM
FRS/BRZ StopTech Brake Pads, Rotors and Lines at Redline360 Redline360 Brakes, Suspension, Chassis 4 01-13-2013 02:42 AM
STOPTECH Performance Brake Pads On Sale!! SpeedBRZ Brakes, Suspension, Chassis 0 07-31-2012 01:54 PM
