Old 01-07-2014, 11:35 PM   #1
G.I.Choe
Drives: 2013 Scion FRS Argento
Dealing with dealership over transmission issues
So I've posted in various threads here about the 5th gear grind (lots of threads about this issue) and I was hoping for some feedback and advice.
I purchased my 2013 Scion FR-S in March of 2013. A few months in, I began noticing a quick, short grind when downshifting from 6th to 5th at highway speeds (usually above 65 mph). My fuel pump started chirping too.
I took it in to the dealer (Bob Smith Toyota in La Crescenta, CA), and they told me they were unable to replicate the grind. They ordered a fuel pump and sent me on my way.
While I was waiting for the fuel pump, my 3rd and 4th gears started making a noticeable crunch, but did not feel like they were grinding. I mentioned this to the dealership when I took it back in after the fuel pump had arrived. They said they were unable to replicate it as well. I requested that they perform a tranny fluid swap, as some of the threads here mentioned that the fluid was pretty bad from the factory. They said they'd have to charge me $180 for that. I said no and took it home.
Finally, after a few months of this going in, my 5th gear grind became intolerably loud, but I didn't want to take it back yet again and have them state that it was unable to be reproduced.
Luckily, @way too fast motorsports got in contact with me over these forums and said that he'd do a fluid swap for cheap. He recommended Amsoil, so I went ahead with it. I took a look at the old fluid, it looked like brown-green puke.
Immediately after the fluid swap, I noticed that my 3rd and 4th gear issues went away, but the 5th gear grind was still there. I took it back to WTFMotorsports and he told me it sounded like a synchro issue.
I took it BACK to Bob Smith Toyota, and they sent a mechanic to ride with me while I tried to reproduce it. I was able to do so, and I mentioned the entire above story to him. However, the moment I mentioned the fluid swap, his whole attitude immediately changed and stated that I had "voided my warranty by performing a fluid swap". From the way he talked, he made it sound like I had slapped in a turbocharger or something.
I went on Amsoil's website and on their warranty page (http://www.amsoil.com/warrantysecure.aspx) it specifically states that using their product does not void my warranty. I mean seriously, it's a fucking fluid swap.
What should I do? I'm going back to the dealership on the 16th (they didn't have any rentals for me to use while they documented the issue), should I print that out and show this to them? Is that dealership just incompetent? And have any of you run into dealership issues like these?
Thanks for taking the time to read this.
G.I.Choe is offline   Reply With Quote
Old 01-08-2014, 12:02 AM   #2
humfrz
It would seem to me that if the transmission fluid that was put into your car's transmission was within the spec range of the manufactures recommendation, the warranty should stand.
I'll go with the theory that it's a bad 5th gear synchronizer.
humfrz
Old 01-08-2014, 12:07 AM   #3
ftc~brz
Done
Drives: WRB BRZ
Too bad your not on the east coast, I have a perfectly good oem transmission you could have.
ftc~brz is offline   Reply With Quote
Old 01-08-2014, 12:09 AM   #4
humfrz
How come ... ??
Or is that a sad story ... ??
humfrz
Old 01-08-2014, 12:10 AM   #5
Muskokan
Drives: white Sport-tech
Some dealerships don't do shit until they know corporate is keeping an eye on them. Phone SOA or Toyota or whoever and open a case number, and as stated, aslong as the fluid is recommended specs they can't void warranty, and I'd mention that to corporate that they even implied it.
Muskokan is offline   Reply With Quote
Old 01-08-2014, 12:18 AM   #6
G.I.Choe
I have an invoice that states that wtfmotorsports used 75w-90 fluid so I'm not worried about the fluid not meeting recommended specs. I will definitely contact scion of America. Thanks for the advice, I also contacted amsoil as well.
Old 01-08-2014, 12:18 AM   #7
strat61caster
strat61caster's Avatar
My gut would be go to another dealer, post in your regional sub forum asking for suggestions. You're in an area with a fuckton of options, use that.
The quickest solution is definitely to contact Scion customer service, corporate headquarters don't fuck around because they know what they can and can't get away with, the dealership is definitely trying to get you to go away. Problem is that the corporate phone zombie will just dump you back to the same dealership you started at, and if you request a different dealer they'll just send you to the next closest location. It's not a good situation to be in, good luck.
http://www.scion.com/contact/
ineedyourdiddly
Old 01-08-2014, 12:26 AM   #8
Drives: V8 Miata
here was the link i forgot to send you Magnuson-Moss Warranty Act
http://www.consumer.ftc.gov/articles...ne-maintenance
way too fast motorsports is offline   Reply With Quote
Old 01-08-2014, 01:44 AM   #9
N1rve
N1rve's Avatar
Drives: 2019 BMW ///M4
Your warranty is NOT voided. As long as the transmission fluid MEETS or EXCEEDS OEM Standards you're fine.
The DEALER has to prove that the fluid caused the failure. YOU don't need to do ANYTHING. This dealer is shady as hell... I wouldn't even step back to that dealership at all. Their yelp reviews aren't doing so good either.
Take it to Longo Toyota. They'll take care of you.
I hate shady dealers, I used to work at one and I quit after 3 months. I'd help you as much as I can.
Old 01-08-2014, 02:05 AM   #10
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
Two things:
1) please go back and tell the mechanic to not throw the word "void" around. Unless he's a lawyer, he has no idea what the word "void" means. They can deny you warranty service, but they cannot void you anything since they are NOT Toyota Motor Corporation.
More importantly, 2) talk to the service manager, and/or the GM of the dealer. If they throw more BS at you, take your business somewhere else. You're in SoCal, you have tons of Toyota dealers that are more than willing to take your business.
And trust me, this is business. May not be full retail labor charges, but they get paid.
-alex
Old 01-08-2014, 11:26 PM   #11
G.I.Choe
After researching, I've decided to cancel my appointment with Bob Smith and take it to Longo Toyota. Thanks for the advice, guys.
Also, Amsoil got back to me with a newly published pdf of their warranties.
Hopefully everything gets resolved and I don't get treated like a piece of shit.
Old 01-09-2014, 01:35 AM   #12
N1rve
N1rve's Avatar
Let us know how it goes!
Old 01-09-2014, 01:38 AM   #13
humfrz
Good on ya, G.I.Choe .....
humfrz
Old 01-09-2014, 02:06 AM   #14
OrbitalEllipses
Drives: Attitude
While you're at Longo, I would go ahead and contact Toyota or Scion corporate/try to get in touch with the regional manager. Complain, complain, complain about this other dealership trying to screw you.
How come ... ??
humfrz
Yes it is.
manual transmission issues. DriftEightSix Engine, Exhaust, Transmission 24 06-10-2013 08:25 AM
Local Dealership Service Issues 31katys Northwest 9 12-29-2012 08:01 PM
manual transmission issues XtremeMaC Engine, Exhaust, Transmission 4 10-10-2012 06:40 PM
Transmission issues... Rob_g Issues | Warranty | Recalls / TSB 13 09-23-2012 07:40 PM
dealership issues.... jarviz Scion FR-S / Toyota 86 GT86 General Forum 36 09-18-2012 03:50 PM
