Drives: Argento Scion FR-S
Dynos vs finals drives, weight loss, etc.
I believe I've ready some dynos can factor in acceleration, but does that include changing final drives, lightening the car, etc.? I feel if many of us are staying N/A that it's important to measure these factors also.
What about other measurements.. 0 - 60, 5 - 60, etc. on a dyno? Or per gear measurements.. slicing 0 - 1XX mpg logs into specific gears? Mike
No? If you take out 300lbs, will it show +whp on some dynos? Or some other measurement?
Señor Member
Drives: BRZ SWP
Drives: 2012 Toyota 86
i think bang for your buck the final drive will gain you the most in terms of acceleration, but alot of people might not be willing to deal with the higher rpms on the highway.
If you take a bunch of rotating mass out of the driveline you might see 1 or 2 hp show up, but you'll feel it A LOT more when you're accelerating.
Drives: car
I've never seen anything more than hearsay on the "real world" answer to these questions. What I'm saying is, there could easily be a difference between what "should" be going on and what happens in the real world. What I can say is this:
Any dyno, set up and maintained correctly, should not be affected by something that doesn't change wheel torque. BUT if I had to name a type of dyno that would be most susceptible to changes in tire size, weight, etc, it would be your typical low-end Dynojet inertia dyno that can't do any loading. This is because an inertia dyno doesn't directly measure torque. It measures how fast the rollers accelerate, to calculate the power, and then back calculates torque if it has an accurate engine speed signal. |
Drives: Sterling BRZ Ltd
When I think of people who appreciate mods like a carbon driveshaft for example. They are not usually the type who are fixated on a dyno number. Lightweight is more of a driver mod. Ive always had the hardest time selling customers on final drives if they haven't experienced them. It is a considerable amount of money that doesn't really come with that tangible HP gain. Once I installed a diff for free in a friends car to prove a point, he then gladly paid after a test drive.
#8 | |
Twin Screw You
Drives: 2013 Supercharged Whiteout FR-S
changing the final drive isn't some sort of unicorn mod though. it doesn't actually make you accelerate faster depending on how far you plan on accelerating, since you have to shift earlier with the shorter gearing. depending on where and how you drive, it could serve you well to go the other way and 'accelerate slower'.
#10 | |
[ame="http://en.wikipedia.org/wiki/Automobile_handling"]Automobile handling - Wikipedia, the free encyclopedia[/ame] What else could be added to this this list? I'm not asking just for myself, but for the thread and to keep building up information. Code:
HP / Torque Displacement, forced induction, N2O, water injection Rotational Mass Lightweight pulleys, cf driveshaft, clutch, brakes Sprung weight Interior, battery, fluids, seats, etc., etc. Unsprung weight Wheels, suspension, brakes, rotors, axles Traction Wheels, alignment, suspension, chassis, track and wheelbase Gearing Clutch, transmission, final drive, wheels Weight distrib. Suspension, engine placement, driver weight/placement Aerodynamics Front lip, wing, underpanels, rear diffuser, cannards http://www.pistonheads.com/gassing/topic.asp?t=858223 http://www.w8ji.com/rotating_mass_acceleration.htm
#11 | |
Drives: Asphalt FRS
#12 | |
#13 |
Drives: Asphalt FRS
Correct, but on that specific car, or at least with my personal experience, it was quicker to 80mph. After that, it hit a wall. Stock gear S2k's could pull past me, especially after 100mph. But yes, below that, I could pull ahead, with the biggest advantage being in 2nd and 3rd gear.
#14 |
Drives: 2006 Cayman S, 2007 Outback 2.5i
Only in first gear, assuming both cars are running it all the way up to redline. Yes, on the highway, with both cars in 5th (for example), the one with the shorter FD will accelerate faster. If both cars are going for maximum acceleration though, the one with the shorter final drive might be in 4th, while the stock geared one might be in 3rd. This pretty much negates the advantage at higher speeds.
| Weight Loss Potential Thread | Entropy | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 79 | 01-16-2017 04:51 PM |
| Importance of weight loss? | ray7792 | BRZ First-Gen (2012+) — General Topics | 80 | 12-13-2013 10:59 AM |
| CEL, Loss of Traction Light, Loss of Power | pituala | Issues | Warranty | Recalls / TSB | 19 | 09-05-2012 11:23 AM |
| Weight loss potential? | SevenTenSplit | Engine, Exhaust, Transmission | 10 | 12-10-2011 02:16 PM |
| weight loss | cynic | Scion FR-S / Toyota 86 GT86 General Forum | 36 | 10-24-2011 04:04 AM |
