Old 01-03-2014, 11:07 AM   #1
zerodark
zerodark's Avatar
Drives: 2015 Series.Blue (WRB Pearl)
Front Bumper Fabrication
Hi FT86Club.com,
As I do not have a lot of experience with body shops or shops that handle custom fabrication of auto parts, I thought I would reach out to the more knowledgeable..
From my understanding the "mustache" on the BRZ front bumper is incorporated into the bumper (can only be removed via a dremmel or similar tool). That being said is it possible/feasible to have a shop create a custom bumper that has a vent in it (see pictures)?
I have seen people dremmel into their front bumpers to create vents for better air flow for intakes.. but I would prefer not to go that route. Just curious if something like this is even within the realm of possibility (I know.. with enough money almost anything can be done)
Thanks all
zerodark is offline   Reply With Quote
Old 01-07-2014, 10:07 PM   #2
Kiske
Kiske's Avatar
Drives: RX-7 / BRZ
Originally Posted by zerodark View Post
Hi FT86Club.com,
Thanks all
90% of your average bodyshops won't touch this.
1. You can cut out the bumper's mustache however you will have the crash beam/bar directly behind it. You can remove this but, your car will be toast should it ever get hit.
2. The bumper is a polyurethane which is a bitch to modify. You would have a better bet trying to find someone to copy the stock bumper into fiberglass/carbon fiber which is easy to mod, repair and add onto. The only draw back being it will weight more and slightest curb bump will crack it.
The Following User Says Thank You to Kiske For This Useful Post:
zerodark (01-09-2014)
Old 01-07-2014, 10:27 PM   #3
Bad Habits
Bad Habits's Avatar
Drives: br zed
With money everything is possible. You know that so barring you find 2-5k laying around for a custom bumper to be designed via cad, prototyped with various materials, a final prototype created for testing fit, etc and a final version you have a couple of options.
1) contact companies that make body kits that have the above resources to see what it might cost for a one off
2) hit salvage yards, find brz bumpers to experiment on so you don't hack up your car.
Try taking a stock bumper and fab your own product. Would think working in fiberglass to create your "vent" to start with would be cost effective on a small scale. Once refined move on to lighter weight material, cf, different abs plastics, etc. Integrate your creation into a stock bumper, trial and error maybe you come up with something that works for you.
Good luck
Bad Habits is offline   Reply With Quote
The Following User Says Thank You to Bad Habits For This Useful Post:
Old 01-07-2014, 11:12 PM   #4
disgruntld
Less than pleased...
disgruntld's Avatar
Drives: '13 BRZ Ltd SSM 6MT
http://www.ft86club.com/forums/showthread.php?t=4265
This thread has at least 2 people that just cut the mustache out and painted the bumper beam. If you think it looks good, I say find a spare and go to town. Good luck, hope this helps.
disgruntld is offline   Reply With Quote
The Following User Says Thank You to disgruntld For This Useful Post:
Racer X Fabrication Suspension group buy: UCA, Rear LCA, Front LCA and more!! Jeff@Racer X Fab Groupbuys 74 06-23-2014 09:08 AM
Swap my BRZ front bumper for your FR-S bumper (GBS/ultramarine) wulfgang Exterior Parts (Aero, Lighting, Etc.) 8 11-26-2013 06:48 PM
WTB: BRZ PS headlight, hood, front wide fenders, front bumper/ body kit Guildjs Want-To-Buy Requests 5 10-31-2013 08:35 PM
Wtb brz headlights and a white front frs front bumper post to Australia. jet86 Want-To-Buy Requests 0 08-20-2013 08:27 AM
BRZ w/ FR-S Front Bumper? CACRUZE Cosmetic Modification (Interior/Exterior/Lighting) 4 08-19-2013 10:13 PM
