Drives: AE86, 2x GT86, TE27
Perrin Super steer for 86?
Drives: FRS
#3 | |
Drives: Sterling BRZ Ltd
That Guy
Drives: 2013 asphalt FRS MT
Drives: Matte Black STI
Actually the amount of force being applied isn't through just the head. Since the bolt is still tightened down to the subframe through the steel sleeve in the bushing, the same load is being applied to the bolt as it was before. The force is being applied from the rack housing through the CNC'ed bodies, through the steel sleeve through the bolt.
Unlike others, we tested these parts on cars for more than a year before they were released and they never had any issues. They never came loose, they didn't add extra noises to the car and we are 100% confident in this part. The fact it can be installed by almost anyone with basic tools in less than 30 minutes of work, makes this part a great option for customers looking to add crisper steering to their car. Regarding the Super Steer. If enough people ask, this may be something we offer. The STI crowd didn't take to these as much as we would have liked, but maybe the BRZ/FR-S/ Drifter crowd may! |
| The Following 5 Users Say Thank You to PERRIN_Jeff For This Useful Post: | Anthonytpt (01-02-2014), diss7 (12-31-2013), Ryaquinn (01-01-2014), s2d4 (01-02-2014), whataboutbob (01-03-2014) |
I'd love to see either this super steer product, or a quick rack developed.
One problem a see with a super steer product would be the nanny electronic shit throwing a hissy, as the steering wheel angle sensor and the actual steering angle would be different, and it might think there's a problem. Not that that worries me, I don't run the ABS fuse. |
#7 | |
I assume the super steer on the older STI and WRX had hydro power steering, would the application of your design be relevant with the electric PS rack? Since you guys have 3 BRZ now I'd be curious to see if it would make any serious difference. But understand the cost/return on investment issue.
86-er
Drives: BRZ tS
So is this out yet? lol
Would love to try it
2018 Subaru BRZ ts 020/500 - My Daily, work car, and track car
Generally Well Liked
Drives: '08 STi Hatch, '11 Outback 3.6R
Does the steering rack lock just go on over the factory bushing? Would it be compatible with aftermarket bushings like the whiteline KSR210 installed?
- AdrianG |
#10 | |
Drives: Toyota 86 TRD Version AT
#11 |
#12 |
Stock is 2.5 turns lock to lock...
#13 |
I have a quick steering kit on the AW11 and it's suppose to be 2.5 turn lock to lock, but the GTS86 definitely does not exhibit the go kart feel and seems to require more input for the same angle as the AW11.
If you are right, I guess what I am wanting is for the super steer to give me same steering angle per input from as the AW11 on the GTS86, perhaps 2 turn lock to lock will do it. |
#14 |
It is 100% 2.5 turns lock to lock, you get 1.25 turns each way. Sounds like you're not after less turns lock to lock but more steering angle overall?
Without knowing the rack ratio on the AW11 and the distance from outer tie rod to ball joint on the knuckle I can't really guess at what else is happening, but I would imagine the shorter wheelbase on the AW11 also helps with what you're feeling. The wheelbase is almost a full 10" shorter on the MR2 than on the FRS/BRZ/GT86 which is a pretty big difference. Any quick steer kit I've seen won't change how many turns lock to lock, just how much steering angle you get for a given wheel input.
| The Following User Says Thank You to wparsons For This Useful Post: | diss7 (01-02-2014) |
| Light popping sound when I steer, even when parked. | Jar | Issues | Warranty | Recalls / TSB | 2 | 06-01-2013 05:27 PM |
| My review of the FRS (RW Steer discussion) | AaronCompNetSys | Scion FR-S / Toyota 86 GT86 General Forum | 86 | 05-10-2013 09:07 PM |
| FS: Perrin 2" Super Shorty Antenna | JPxM0Dz | Canada Classifieds | 1 | 03-18-2013 06:46 PM |
| The next step in removing feedback from cars: steer-by-wire | cyde01 | Other Vehicles & General Automotive Discussions | 9 | 10-18-2012 04:00 PM |
| BeSpoke steer anybody to BRZ? | trackmagic | Electronics | Audio | NAV | Infotainment | 7 | 05-21-2012 12:54 AM |
