Old 12-29-2013, 04:06 PM   #1
brn12345
brn12345's Avatar
Talking Installed Revolution 4-2-1 EL header
Installed my Revolution 4-2-1 EL header today! I got this header from www.Japanparts.com (thanks!) who kindly ordered it for me from http://www.revo-tune.jp/ . The build quality is very good as expected from a Japanese header and it had a nice double slip joint with springs to solve the expansion issue. In my view a much better solution than the flexible joints. I did have to by new OEM gaskets though, which I got from http://www.jp-carparts.com/ (thanks Osamu!) and I also had to supply two nuts and bolts for the header to up pipe connection. The header also came with only 1 oxygen sensor bung installed so I installed another one 3" downstream with an 1.5" stand off.
Here are pics of the headers on the floor, installed, making the extra O2 bung and a video after the install. It sounds very mild in this video but let me tell you it screams, the iPhone microphone doesn't do it justice. Planning to try and dyno sometime this week.
Big thank you to Hani at Zspeed Performance for the install!
Enjoy.
[ame]http://youtu.be/xoChPG-5Vf8[/ame]
Updated 1/1/2014:
So I took the BRZ to the Dyno and here is a photo of the run. It put down 183whp. Also here is a link to Datazap for the same run if anyone wants to dig deeper.
http://datazap.me/u/brn12345/dyno-run-headers?8-27
brn12345 is offline   Reply With Quote
Old 12-29-2013, 06:30 PM   #2
Freeman
Freeman's Avatar
Drives: 2013 Ultramarine FR-S
In for dyno updates
sent from my locker... help!
Freeman is offline   Reply With Quote
Old 12-30-2013, 11:04 AM   #3
BRZ?
Drives: 2014 SWP 6MT BRZ
Wow this one of the nicest manifolds I've ever seen, please let us know how it does with dyno testing
BRZ? is offline   Reply With Quote
Old 12-30-2013, 01:09 PM   #4
projectXTR
Drives: Sterling Silver BRZ
dat sound tho !
projectXTR is offline   Reply With Quote
Old 12-30-2013, 04:13 PM   #5
Grip Ronin
The Mechanic
Grip Ronin's Avatar
Drives: Civic Turbo,FR-S
thats nice. sounds raw.. no sound tube?
IG-Joey_Soul
Old 12-30-2013, 04:21 PM   #6
brn12345
brn12345's Avatar
No sound tube. Stock airbox with panel filter and tomei cat back. Obviously the headers too. I am still running stock mid and up pipe with the secondary cat and resonator.
2013 Lightning Red - 6MT
Perrin Inlet Hose ~ TRD Panel Air Filter ~ OEM Modified Snorkel ~ Revolution 4-2-1 EL Header ~ HKS Resonated Front Pipe ~ BRZedit self tune ~ KW Clubsport Coilovers ~ AP Racing Big Brake 4 Piston ~ Whiteline Front Endlinks ~ Perrin Rear Endlinks ~ WedsSport TC105N 17x8 42+ ~Dunlop Direzza II Star Spec 225/45/17 ~ STI Trunk Lid Spoiler
Old 12-30-2013, 07:58 PM   #7
Grip Ronin
The Mechanic
Grip Ronin's Avatar
nice, we have similar setups both on oft tune. let me know if you dyno
IG-Joey_Soul
Old 12-30-2013, 09:21 PM   #8
Enraged21
#RememberTheBuster
Enraged21's Avatar
Drives: Firestorm FRS MT
love the sound of equal length
Enraged21 is offline   Reply With Quote
Old 12-30-2013, 09:26 PM   #9
jonbatz01
jonbatz01's Avatar
Drives: ZD8
Yummy.....did u have to extend the 2nd O2 wire?
I disconnected my 2nd O2 sensor and tuned it out with Ecutek
EOJ | PERTH | ZD8
jonbatz01 is offline   Reply With Quote
Old 12-31-2013, 05:10 AM   #10
brn12345
brn12345's Avatar
The Revolution header came with only one O2 sensor fitting. I welded in another about 3" downstream and put about 1.5" extension. The rear sensor is okay in terms of wire length. The main front sensor fit fine but the wire would not route the oem route so I just tie wrapped it in place.
Old 01-01-2014, 03:16 PM   #11
brn12345
brn12345's Avatar
Added dyno and datalog
Old 01-01-2014, 03:31 PM   #12
Tye300
Tye300's Avatar
Drives: Toyota 86 TRD Version AT
Damn that sounds good!
Tye300 is offline   Reply With Quote
Old 01-01-2014, 08:44 PM   #13
enjoyminutemaid
enjoyminutemaid's Avatar
Drives: Subaru BRZ Limited WRB Manual
Pretty expensive for a header not including ceramic coating and needing modification for O2 sensor stuff, but it looks nice and the fitment must be much easier with that design.
I really like their front pipe that has a cat and a small muffler, kinda like our oem front pipes. I wish more companies would offer this. I know Nameless has a catted and hemholtz-resonated front pipe, but I doubt that this reduces overall volume the way Revolution's small muffler/resonator probably does.
enjoyminutemaid is offline   Reply With Quote
Old 01-01-2014, 09:10 PM   #14
ramiram1984
Drives: 2016 STi DGM
Ya id rather just spend on FI for that much
-2014 SSM BRZ MT
ramiram1984 is offline   Reply With Quote
bahrain, brz, header
Borla UEL Header installed = CEL! jordanrw260 Engine, Exhaust, Transmission 83 06-12-2016 12:53 PM
Installed my PPE Engineering header Evil86 Engine, Exhaust, Transmission 47 07-16-2014 08:25 PM
Installed header. should i do front pipe? WhiteFR-S Engine, Exhaust, Transmission 9 10-04-2013 04:16 PM
P&L Header installed and rockin'! mtimney Engine, Exhaust, Transmission 8 08-11-2013 09:19 PM
Perrin Header Back Installed!! tonytduc Engine, Exhaust, Transmission 1 01-03-2013 10:58 PM
