Old 12-28-2013, 04:24 PM   #1
Hanni_0176
Hanni_0176's Avatar
Drives: 2013 Scion FR-S 10 Series MT
CEL U0037
I tried looking this up online, but the only information I can find for CEL U0037 is "Communication Bus A" and/or "Communication Bus B"
Anyone have any idea what this is, what may have caused it, and any possible solutions to fix it?
Mods: K&N Air Filter - Open Flash Tablet (Stage 1 v1.55) - more to come!
Hanni_0176 is offline   Reply With Quote
Old 12-28-2013, 04:58 PM   #2
mike_ekim1024
mike_ekim1024's Avatar
Drives: Argento Scion FR-S
I don't remember which code it was but I had a few network related ones when I use my Bluetooth obd adapter with my ecutec tune. I just clear it with torque but it's annoying. One time just got gas, and got the cel starting up the car.
mike_ekim1024 is offline   Reply With Quote
Old 12-28-2013, 04:59 PM   #3
Hanni_0176
Hanni_0176's Avatar
I removed my bluetooth adapter from the OBDII connection, shut the car off, turned the car back on, and the CEL was still there.
I guess I'll clear the code, and hope it doesn't come back on.
I appreciate your assistance.
Old 12-28-2013, 05:58 PM   #4
mikalem
mikalem's Avatar
Drives: 2020 DGM BRZ Limited
I've seen it before on my car with the Bluetooth adapter - under the impression that it causes some disruption in communication between ecus in the car. Once tripped it seemed to hang around - needed to use ecutek (or torque) to clear the code - once it was cleared it didn't come back... Yet. Seems from reading the knock off adapters cause it more often than not.
Sent from my SGH-M919 using Tapatalk
mikalem is offline   Reply With Quote
Old 12-28-2013, 09:34 PM   #5
1Cor10:23
1Cor10:23's Avatar
Is that possibly a typo for 0073? If so, that's from using torque or any other BT app - occurs when the app is connected to the adaptor before the car is turned on. You should only connect the BT after car is on to avoid 0073. It's safe just to clear if it is 73.
Sent from my SGH-I317M using Tapatalk
