Drives: 1997 Eagle Talon TSi AWD
Testing The Waters
Are you guys interested in forged rods (I and H beam), forged pistons (with much lower compression -- 8.5:1, 9.0:1), aftermarket head studs?
| The Following User Says Thank You to Jason@DSG For This Useful Post: | Xero-Limit (12-28-2013) |
Boosted
Drives: Not a supra....yet
8.5:1...but why?
Drives: FR-S 6MT
| The Following 2 Users Say Thank You to Mikem53 For This Useful Post: | Jason@DSG (12-28-2013), suaveflooder (12-28-2013) |
Drives: Scion FR-S
Lots of wasted energy while needing more boost to produce the same results with higher compression pistons.
@SkAsphalt Last edited by ciro; 12-28-2013 at 11:23 AM. Reason: picky picky people. |
| The Following 2 Users Say Thank You to ciro For This Useful Post: | Dephective (12-28-2013), SkAsphalt (12-28-2013) |
Ridge Racerrrrrrrrr
Mmmm this was written poorly.
Boosted
I run 9.0:1 on 28-30psi for 500whp
I think 9.0:1 will be the way to go. ***for big boost applications*** 10.5 would be a good choice for a more conservative approach on lower - moderate boost Last edited by Jason@DSG; 01-07-2014 at 08:39 PM. |
with di and e85 i don't see the need to go lower than 10:1, just means the turbo has to work harder to make the same power.
| The Following 4 Users Say Thank You to jamesm For This Useful Post: |
ya i think 8.5:1 pistons went out with primitive tuning. anyone remember the days of stock injectors and fmu's? 10:1 with actual tuning would be perfect.
btw, will these be house brand? or something from arias, wiseco, je, etc.? IMO, these products will be very beneficial for this platform so I vote yes! |
#10 |
Much title. Wow.
Drives: 2013 BRZ Sport-Tech
Yes.
Very interested. |
| The Following User Says Thank You to Deadspool For This Useful Post: | Jason@DSG (12-28-2013) |
#11 | |
Drives: Daihatsu
#12 |
Drives: toyota mr2/ Toyota GT86
Chaps
Making power on a FI can go a couple of routes its a balancing act and always has been if you have a a high static compression you run a bit less boost and possibly a bit more spark if you have lower compression you run a bit more boost and bit less spark - so yes you typically will experience less lag on the former solution but also you will be limited on the amount of power you make other factors such as bore size, combustion chamber shape, fuel mix formation, rpm, torque curve shape etc etc all come into this every engine is different and even then there's no 'right' approach - just different techniques with different compromises |
| The Following 3 Users Say Thank You to 350matt For This Useful Post: |
#13 |
Big Member
Drives: 2014 FR-S
I've always heard that you want lower compression with turbo, so there is less chance of "detonation" and knock. And that you want higher compression for s/c or just n/a.
So yea this makes sense to me. But I don't really quite understand what I'm talking about anyway. Still, I wouldn't put a turbo on these stock high compression engines. |
#14 | |
| TESTING WATERS: 18x10 MATTE BLUE XD9 | mr. slim | Wheels and Tires | 8 | 10-18-2013 09:31 PM |
| Testing Waters: Stivo Wing in asphalt gray | DarkCard | Exterior Parts (Aero, Lighting, Etc.) | 3 | 10-08-2013 12:49 PM |
| Testing Waters - Ful LED changeover $105($109 With Switchbacks for FRS) | eljefe | Interior Parts (Incl. Lighting) | 11 | 08-09-2013 02:23 AM |
