Old 12-27-2013, 08:58 PM   #1
Hawk77FT
Drives: GTS 86
Steering wheel correction
Hi all,
I've had this issue for quote some time: if I go on a large bend just at the exit the steering wheel goes a bit crazy...I thought initially that the traction control tries to kick in and correct my driving but even after the traction control deactivation, still does it...is more like the steering wheel wants to go a bit more than it correct it self. I drove another 86 and it felt beautiful, while mine is stiff and hard. I lowered the car thinking that it might correct the oversteer but no. I have also installed the Ktd425 Whiteline to maintain the geometry of the suspension, but I still have issues.
Anyone know why?
Sent from my HTC One X using Tapatalk 2
Hawk77FT is offline   Reply With Quote
Old 12-28-2013, 01:08 AM   #2
humfrz
Originally Posted by Hawk77FT View Post
Hi all,
Anyone know why?
Well, I don't know why ..... but, if you haven't already done so after your mods, I would suggest you have a good alignment done....
I hope you get er tracking better.
humfrz
Old 12-28-2013, 03:49 AM   #3
Hawk77FT
Drives: GTS 86
humfrz
I have had a wheel alignment done couple of times.
Old 12-28-2013, 05:45 AM   #4
Muskokan
Drives: white Sport-tech
You the first owner? Stock tires? Tire pressures?
If all else fails and it's as bad as you say compared to other 86's, return suspension to stock and take er in. If you can notice the techs should.
Muskokan is offline   Reply With Quote
Old 12-28-2013, 10:06 AM   #5
Suberman
Drives: Subaru BRZ Sport Tech Satin White
Sounds like a castor issue, but that is fixed on these McPherson strut cars.
How low did you go?
Also, wider tires or wheels with non standard offsets can cause these issues.
Suberman is offline   Reply With Quote
Old 12-28-2013, 10:59 AM   #6
SloS14
SloS14's Avatar
Drives: 2013 FR-S whiteout
That could be an electric steering issue. IS350's/250's had a weird problem
https://www.google.com/search?q=is35...sm=93&ie=UTF-8
SloS14 is offline   Reply With Quote
Old 12-28-2013, 11:15 PM   #7
krayzie
Drive From Home
krayzie's Avatar
Drives: BRZ STI Performance
I've driven a new 2009 IS250 AWD one time, the electric steering on that car has really slow response. You can feel the motor having trouble catching up with steering input (feels like really bad force feedback when playing Sega Outrun at the arcade back in the 80's). Actually I've also driven a 2007 Civic a few times with the exact same behavior. If I've never had a car with proper electric steering (Mk.5 Golf GTI) I would have thought modern electric steering sucks big time! The electric steering on my BRZ is really good I rank it on par with the GTI.
Can't you change the castor by shifting the subframe? Check the subframe bolts are tight? Sorry I'm not too familiar with this car yet.
krayzie is offline   Reply With Quote
Old 12-30-2013, 12:25 AM   #8
Hawk77FT
Drives: GTS 86
Just got it in to Toyota, but apparently the idiots that did the wheel alignment before stuffed the 0 point of the steering wheel. They need some sort of tool to identify the problem which they didnt have at the time. I will check in sometimes next week with them.
i really hope is something minor and not major, but by the sounds of it, it can be a number of other things.
Old 12-30-2013, 01:40 AM   #9
humfrz
..........., but apparently the idiots that did the wheel alignment before stuffed the 0 point of the steering wheel..... .
.......?? ...... what that means.
humfrz
Old 12-30-2013, 04:01 AM   #10
Hawk77FT
Drives: GTS 86
humfrz
The steering wheel and basically the whole steering assembly has a 0 point which is the middle point of the steering rack.
Old 12-30-2013, 11:30 AM   #11
humfrz
.....but, what does "stuffed" it mean .. ??
Maybe that's a "down under" term .... maybe I should get out more .. ??
humfrz - lost ... again ..
Old 12-30-2013, 11:40 AM   #12
onefitz
Drives: 13 GBS BRZ
"Stuffed it".. F'd it... Screwed it up. I think you get the idea now
onefitz is offline   Reply With Quote
Old 12-31-2013, 10:57 AM   #13
Suberman
Possibly survived from WWII flying slang like "bought the farm."
TRD Steering Wheel DSOmegaX Cosmetic Modification (Interior/Exterior/Lighting) 26 04-30-2016 06:15 PM
WTB: Stock steering wheel (wheel not airbag) mobybrz Interior Parts (Incl. Lighting) 2 09-11-2014 02:23 PM
scion frs steering wheel air bag and steering wheel Jhon19lopez Interior Parts (Incl. Lighting) 7 01-04-2014 06:04 PM
Swapping steering wheels with a new tC steering wheel. jonathan9573 Cosmetic Modification (Interior/Exterior/Lighting) 4 12-20-2013 11:45 PM
BRZ STI Steering wheel??? tacoss23 Cosmetic Modification (Interior/Exterior/Lighting) 9 08-26-2013 07:30 PM
