Old 12-27-2013, 12:56 PM   #1
Robert95g
Drives: 2013 FR-S Whiteout
18x9.5 wheels in front?
Hey everyone, I'm just curious if I could fit 18x9.5 in the front? I was going to do a staggered setup and do a 8.5 front and 9.5 back but I wanna be able to rotate my tires and not go through that extra trouble. So should I just go 9 wide all around to be safe, or 9.5 or what do you guys suggest? Also I'm on eibach sport lines.
Robert95g is offline   Reply With Quote
Old 12-27-2013, 01:11 PM   #2
FR-S Matt
You can, but you can't go wider than 245 tires on most springs. Even then, the clearance is very small. Recommend coilovers to properly run that size up front or you need spacers.
I run 18X9.5 +38 on a squared setup. It was very close up front on stock springs. I went with coilovers and now I've got 4 inches of clearance from the spring perch to the wheel.
Old 12-27-2013, 01:15 PM   #3
Robert95g
What if I just got a lower offset? I've been told the problem is not even being close to the spring but the fender wall?
Old 12-27-2013, 01:25 PM   #4
mfbmike
Drives: 2013 FRS, 2008 R32
18x.9.5 fits fine with coilovers. Fender rubbing will only happen depending on how low you are and how wide a tire you run in which case, fender rolling provides the necessary clearance.
mfbmike is offline   Reply With Quote
Old 12-27-2013, 01:58 PM   #5
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
http://www.ft86club.com/forums/showthread.php?t=7535
Old 12-27-2013, 02:00 PM   #6
ModBargains.com
ModBargains.com's Avatar
Originally Posted by mav1178 View Post
+1 It's been done before. Check the thread here ^^
ModBargains.com is offline   Reply With Quote
Old 12-27-2013, 07:57 PM   #7
Bl1tzkr1eg
Drives: Toyota 86
18x9.5 will fit the front as long as you dont go wider than a 245 tire
Bl1tzkr1eg is offline   Reply With Quote
Old 12-27-2013, 11:41 PM   #8
MeFryRice
Drives: '13 SWP BRZ
I'm currently running a 255 Michelin PSS without rubbing.
MeFryRice is offline   Reply With Quote
Old 12-28-2013, 10:09 AM   #9
UltraMarine86
UltraMarine86's Avatar
Drives: Ultramarine '13 FR-S
Im running 18x9.5 +45 with 255/35/18 all around and doesnt rub. But theyre right, its only possible with coilovers
Sent from my SCH-I605 using Tapatalk
UltraMarine86 is offline   Reply With Quote
Old 12-28-2013, 10:50 AM   #10
WHITE
Thats pretty neat
WHITE's Avatar
Drives: LOADING......
I had 18x9.5 +38 with a 255/40 PSS on the front and it cleared the stock spring/strut and cleared the firewall.
WHITE is offline   Reply With Quote
Old 12-28-2013, 11:03 AM   #11
switchlanez
Glorious BRZ Master Race
switchlanez's Avatar
Drives: Subaru Libird
What make/model tire? Have you physically seen your inner/outer clearance at full lock or do you think 265/35 would fit, no issues or fender mods?
I'm getting 18x9.5 and still undecided on tires.
Wheel Directory: XXR 530 18x9.75 +20 alexfrspr Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 28 02-09-2017 08:02 AM
** Volk TE37SL 18x9.5 +40 (Rear) 18x9 +45 (Front)** SOURCE,LLC Wheels and Tires 23 09-17-2013 09:25 PM
18x9,5 + 28 in front? grostoine Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 3 09-15-2013 04:17 PM
18x9.5 +45 (square) VS 18x9.5 +35 Front 18x8.5 +40 Rear (staggered) Funky Fresh Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 42 05-07-2013 09:52 AM
18x9.5 front? Flako Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 18 03-27-2013 01:30 PM
