Old 12-26-2013, 07:31 PM   #1
Mordecai
Drives: 2014 Subaru BRZ Sport-Tech
Clear coat scratches...
Tried to take the dealership protective film goo off, and this is what happened:
It goes on for about 6 inches on the drivers side fender plus another 2, 4 inch long scratches near the rear passenger side window.... What's the best way to get rid of them?
Mordecai is offline   Reply With Quote
Old 12-26-2013, 07:59 PM   #2
Shad0ez
Shad0ez's Avatar
Drives: 2013 Raven Black
Starting from the least aggressive based on how it looks from the picture, I would first try a rubbing compound or heavy swirl remover with a medium to heavy cut polishing pad. If you don't have a machine buffer you can try to polish it out by hand. If that fails you can wet sand. I'd go with 2000 grit. Don't be shocked at the haze left after wet sanding. After wet sanding, use a swirl remover and polish until its not even noticeable.
Shad0ez is offline   Reply With Quote
Old 12-26-2013, 08:07 PM   #3
Mordecai
For swirl remover/rubbing compound, which would you recommend?
I've been looking at Meguiar's Scratch x 2.0.
Old 12-26-2013, 08:22 PM   #4
SVThis
SVThis's Avatar
Drives: Scion FRS
I'd use at least a Porter Cable DA. Then hit it with Menzurna FG400 compound, then finish with Menzurna SF 4000 or 4500 polish
We're not happy till you're not happy
2013 Scion FRS Whiteout 6MT
SCCA RTR/Konis/RPF1's/Dunlop Z2's/Strano front bar/CG Lock/Crash camber bolts/JPM shift boot and Instrument panel cover.
SVThis is offline   Reply With Quote
Old 12-26-2013, 09:13 PM   #5
SloS14
SloS14's Avatar
Drives: 2013 FR-S whiteout
I'm a fan of Meguiars Ultimate Compound (plus you can buy it locally). Haven't tried it on the 86's paint yet though.
SloS14 is offline   Reply With Quote
Old 12-26-2013, 09:24 PM   #6
Mordecai
That's exactly why I was thinking something Meguiar's. Its the only stuff I have readily available near me.
Old 12-27-2013, 11:35 AM   #7
Shad0ez
Shad0ez's Avatar
You can try Meguiars or 3M compound. Just make sure you follow up with a polish afterwards and repeat until you can't tell there was ever anything there. Then top it off with a sealant or wax. In the event a compound/heavy swirl remover won't work, read up on wet sanding.
Clear Coat sierra Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 2 06-28-2013 10:21 PM
Scratches through Opti-Coat sc0urge Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 5 03-14-2013 03:28 PM
Clear Coat Help Mr. J Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 6 12-28-2012 10:22 AM
Opti-coat and Clear Bra benoh Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 14 07-19-2012 07:53 AM
opti coat + clear bra wallace03 Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 21 06-21-2012 07:09 AM
