Trim the Fat & add Boost
Drives: sometimes I fly
Delete
Delete
Drives: FRS
is there a difference at all?
Drives: 13 CSB BRZ Ltd
There is a difference in almost every way. The gauge faces are different. The lighting is different.
The main problem with a swap will be programming the mileage. It's stored in the cluster, not the ECU of the vehicle. |
Drives: 86 GTS White
I believe I read somewhere a while ago that the cluster and a bunch of other parts talk to each other using PSK (Pre-Shared Key) based encryption. Which means that you'll have to program the new cluster to talk to the other bits (such as ECU).
It basically means that you'll have to replace a bunch of other parts so that they are compatible with the new cluster. I've never actually tested this myself, so it could be complete bullshit. But that's just what I've read. |
| BRZ cluster gauge swap? | InYOHface | Cosmetic Modification (Interior/Exterior/Lighting) | 31 | 03-25-2017 06:31 PM |
| Can speedometer be wrong? | Walla Walla | Issues | Warranty | Recalls / TSB | 24 | 02-16-2017 08:58 AM |
| F/S: FR-S instrument cluster | MissDeb | Audio/Visual, Electronics, Infotainment, NAV | 5 | 04-08-2014 04:02 PM |
| Vibration/Noise near instrument cluster? | nktech | Scion FR-S / Toyota 86 GT86 General Forum | 11 | 03-28-2014 08:42 AM |
| WTB: FRS instrument cluster | jabbajaw99 | Interior Parts (Incl. Lighting) | 3 | 02-14-2013 01:31 PM |
