Old 12-20-2013, 03:16 PM   #1
Frs32907
Drives: Asphalt grey, manual Fr-S
Will torque app measure correct afr for supercharger?
I'm using the torque app on my android tablet and have seen my air fuel measured but is it accurate enough for supercharger setups and same goes for the boost reading in the app?
Thanks for any info
Frs32907 is offline   Reply With Quote
Old 12-20-2013, 03:21 PM   #2
Ryan86
Road Warrior
Ryan86's Avatar
Drives: Toyota 86 Satin Pearl White
Thanks for any info
I use torque pro, and verified readings against ecutek data logs and they match. Info is from your ECU.
MAF, AFR, Boost all work and pretty accurate.
remember if you have your stock MAP sensor in you cant read boost as the MAP max is .1bar 3psi
Ryan86 is offline   Reply With Quote
Old 12-20-2013, 03:29 PM   #3
Frs32907
I have a manual boost gauge but wanted to make sure afr would be correct. What should it be at with a supercharger on it
Old 12-21-2013, 04:02 AM   #4
jamesm
i wouldn't rely on the stock o2 sensor for any kind of tuning. monitoring, sure. same goes for torque and the common obd2 adapters (ELM327). they're fine for glancing and getting some assurance that things are ok. they're completely useless for any sort of data collection for the purpose of tuning the car.
Old 12-21-2013, 06:39 AM   #5
Ryan86
Road Warrior
Ryan86's Avatar
Fully agree, never new the question was to use Torque to tune with.
I purely use Torque as a reference tool.
Old 12-21-2013, 09:05 AM   #6
Frs32907
Car is tuned just wanna be able to monitor the air fuel with out adding another gauge in the car. I have a boost gauge already so will torque monitor air fuel okay for a supercharger application i guess is my question
Old 12-21-2013, 09:47 AM   #7
Malt
Drives: 2015 WRX
yes
Malt is offline   Reply With Quote
Old 12-22-2013, 09:38 AM   #8
gdrider77
gdrider77's Avatar
Drives: Subaru BRZ Limited
No. You need a wideband.
Torque will only use the stock sensor which is limited to around 11.02 I believe.
So say you start running real rich, you won't ever know. For a FI setup get a dedicated wideband for more accurate readings.
gdrider77 is offline   Reply With Quote
Which EL Header Correct Torque Dip Best? slava Engine, Exhaust, Transmission 56 02-20-2019 08:50 AM
How do Japanese measure exhaust dB? Captain Snooze Engine, Exhaust, Transmission 1 12-24-2012 04:26 AM
waxing: stopgap measure? rainmonkey Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 3 09-12-2012 10:21 PM
Can someone with a BRZ limited measure the foglamp size (housing not bulb) Norkoastal Cosmetic Modification (Interior/Exterior/Lighting) 0 08-28-2012 12:31 AM
Would someone measure their BRZ's front emblem for me? avusblue BRZ First-Gen (2012+) — General Topics 5 07-08-2012 04:44 PM
