Old 12-20-2013, 12:12 PM   #1
CajunFRS
Drives: Challenger R/T, CRX SI,
Scion FR-S Turbo Hybrid Sedan Comes Into Focus
[Mods please leave as separate thread. - Hachi]
Motortrend dropped and article I thought was interesting.
http://www.motortrend.com/future/fut...es_into_focus/
"Yes folks, a turbo. But not just any turbo. Toyota will insist on a 2.0-liter turbo-boxer being bolted to a revised version of its tried and proven hybrid system, pumping out around 300 hp. In addition to a hybrid turbo powerplant, Toyota’s R&D department is currently testing in-wheel motors. Fitted at the front, they would make the four-door an all-wheel-drive sedan."
Yum. I started this in the FRS thread but I know some of you might not visit it. I thought it was and interesting read.
The mid-2012 launch of the Scion FR-S / Toyota GT86 and Subaru BRZ sent shockwaves around the motoring world. The twins, especially the Toyota, put reasonably priced rear-drive Japanese sports cars back on the map. GT86 suppliers have struggled to meet demand. Above, a rendering shows what a GT86 sedan could look like. So it’s no surprise the family will grow. Recent concepts have indicated at least a convertible and a possible shooting brake. But the big surprise will be under the hood.
First , Toyota unveiled the expected at the Geneva Motor Show: A convertible. Then Subaru showed a wagon BRZ concept in Tokyo. Now, the next piece of the puzzle is slowly coming into focus: a GT86-based four-door sedan. A source close to Toyota has divulged that Subaru’s Cross Sport provides telling hints of what the Toyota four-door will look like. “It’d be easy to bring the B-pillar forward, add a rear door and slant the rear roof section to create a viable sedan look,” said our source.
Bearing a development code of 734A, we’re told the GT86 sedan measures 187 inches long, 70 inches wide, 55.1 inches high. It rides on a 108.2-inch wheelbase. Making the car about the same size as Subaru’s current Legacy, the four-door will be 20.1 inches longer and 4 inches taller than the 86 overall, and its wheelbase 7.3 inches longer. Given the 86 sedan’s extra size and weight, the stock coupe’s 200-hp 2.0-liter boxer engine would need beefing up. A source tells us that in place of the naturally aspirated 2.0-liter four-cylinder would be a combination that was initially said to be impossible for the 86. Yes folks, a turbo. But not just any turbo. Toyota will insist on a 2.0-liter turbo-boxer being bolted to a revised version of its tried and proven hybrid system, pumping out around 300 hp. In addition to a hybrid turbo powerplant, Toyota’s R&D department is currently testing in-wheel motors. Fitted at the front, they would make the four-door an all-wheel-drive sedan.
However, rather than a full-time AWD set-up, the idea would be to employ this in-wheel motor system at the front-end to act like Honda’s SH-AWD system. In other words, the system would only engage when rear-end traction is broken to quickly restore stability. Of course, cost remains an important point for the R&D team. What will the market pay for expensive in-wheel motors and a hybrid-turbo powertrain-- more than $30,000 for the standard 2.0-liter turbo and upwards of $40,000 for the hybrid turbo AWD? Our source suggests Toyota will test the waters first, by introducing a 2.0-liter turbo sedan by late 2016. Depending on its success, it could follow this up with an AWD hybrid powertrain – in either the same car or a Lexus model.
CajunFRS is offline   Reply With Quote
Old 12-20-2013, 12:15 PM   #2
ZionsWrath
Thanks
ZionsWrath's Avatar
nty
Old 12-20-2013, 12:18 PM   #3
86-tundra
Troll Hunter
86-tundra's Avatar
Drives: fr-s, tundra
That's disgusting
86-tundra is offline   Reply With Quote
Old 12-20-2013, 12:22 PM   #4
Hachiroku
Administrator
Hachiroku's Avatar
Drives: Boxster 986
Thanks for sharing.
Hachiroku is offline   Reply With Quote
Old 12-20-2013, 12:23 PM   #5
kbogarto
Drives: 2013 BRZ limited WRB
I love the BRZ because of its simplicity. This frs sedan seems awfully complicated
kbogarto is offline   Reply With Quote
Old 12-20-2013, 12:38 PM   #6
Zaku
-Proud of Brzerhood-
Zaku's Avatar
Drives: '17 BRZ CWP LMT.
so it's basically a Toyota WRX? am I reading this right? and if it's the same size as the Legacy...that's pretty big that's a mid sized sedan right? I was hoping for something comparible to the coupe... like an Integra Sedan something along that size.
Old 12-20-2013, 12:38 PM   #7
Meehow86
Drives: 2013 Subaru BRZ Premium 6MT
Agreed. Not sure I'd want to deal with a hybrid turbo.
Meehow86 is offline   Reply With Quote
Old 12-20-2013, 12:44 PM   #8
the new guy
Drives: 2014 Asphalt FR-S/2018 Thunder GT
NOPE NOPE NOPE
the new guy is offline   Reply With Quote
Old 12-20-2013, 12:46 PM   #9
DarkSunrise
DarkSunrise's Avatar
AWD, hybrid, turbo, sedan? 20" longer, 4" taller, 7" longer wheelbase? Probably 3000+ lbs?
I don't know how they could, in good conscience, call this an FR-S/86 sedan.
2022 BRZ Build
2013 FR-S Build
Old 12-20-2013, 12:48 PM   #10
ShadowSeraph
Tech Master / Car Geek
ShadowSeraph's Avatar
Drives: 2013 AT Hot Lava FR-S
yuck. IMO not a GT86 if it is made into a sedan/covertable or what have you..
Perrin: Crank pulley, 3" Cat back, Nameless: 3" FP/OP
GFB: water and alternator pulleys
Borla: UEL Header
Hyper Black ROTA T2R 18x9.5, DSS CF Shaft for AT
-= OFT - Stage 2 UEL E85 - fine tuned by me. =-
ShadowSeraph is offline   Reply With Quote
Old 12-20-2013, 12:53 PM   #11
imag
Drives: 1965 Datsun Roadster
Yeah - I am not seeing why Subaru would build competition for the WRX.
Other than admitting that they seriously screwed up on the WRX styling
imag is offline   Reply With Quote
Old 12-20-2013, 12:56 PM   #12
strat61caster
strat61caster's Avatar
When pigs fly.
That drivetrain sounds like it belongs in the BMW/Toyota joint venture rather than an economical 86 sedan which would have to slot in well under $35k to have a chance in the N.A. market.
ineedyourdiddly
Old 12-20-2013, 12:56 PM   #13
manonastick
Drives: WRB ZC6
it will be like the next toyota chaser lol
manonastick is offline   Reply With Quote
Old 12-20-2013, 01:09 PM   #14
trekkie
Drives: 2011 Camry Hybrid
i could care less about a sedan, but can see why they are doing it. Toyota has nothing in the 'fun sedan' model line up which is why I'm looking at the FR-S Monogram or elsewhere.
The hybrid AWD is interesting, I became a big believer of AWD sports cars when I used to have an Audi TT >10 years ago, and always wonder why more don't do that (outside cost)
trekkie is offline   Reply With Quote
Scion FR-S Turbo Hybrid Sedan Comes Into Focus CajunFRS Scion FR-S / Toyota 86 GT86 General Forum 12 12-20-2013 05:15 PM
Car Wars: Scion FR-S vs Ford Focus ST 86_Insider FR-S / BRZ vs.... 29 09-23-2013 08:46 AM
Helping my Dad Out (Focus ST vs. Veloster Turbo) HunterGreene Other Vehicles & General Automotive Discussions 61 05-07-2013 10:59 AM
Possibility of Scion Sedan? KidWonder Other Vehicles & General Automotive Discussions 6 12-16-2011 05:53 PM
why do we assume no hid lights? subaruslow Scion FR-S / Toyota 86 GT86 General Forum 6 12-01-2011 02:39 AM
