Drives: 2013 Black FR-S
Analyze AFR and Dyno
Here is a Virtual Dynograph of my completely stock ROM on a completely stock car.
Why is there a weird AFR bump in the lower rpms. I looked at the actual ECUTEK logs and it is indeed there on both WOT pulls. It happens well within WOT so it isn't partial throttle or anything. Is this normal or something to be concerned about? ![]() here is the log to go with it: green = AFR blue = fuel rail press red = fuel trim long term yellow = fuel trim short term
i'm guessing that's a stock o2 sensor that hasn't been scaled down. if that's the case, the you're just seeing a tiny bit of what's going on there, the moment that the came above 12.x:1 before settling somewhere lower in the range.
it's not uncommon to have a bit of motion in the afr when you first step on the throttle. normally if it's really bad it'll be because of throttle delta compensation requiring some adjustment, though without a wideband you won't be able to tell for sure. it can take longer than you might imagine for the afr to settle down to target, especially if the calibration isn't spot on. i wouldn't worry about it unless it's presenting a driveability issue. |
#3 | |
What about fuel rail pressure tapering off at higher RPMs like that? Not a concern? I have a high flow fuel pump in the tank and I just removed a supercharger which required tampering with the fuel rails. Just want to make sure I didn't mess anything up. |
#4 | |
Drives: 2013 White Out FR-S
They all taper in the higher rpm range unless you change it for a specific reason.
| POST UP YOUR DYNO FIGS!![Nat. Asp]DYNO Figures (BEFORE and AFTER) | stevo_12v | Engine, Exhaust, Transmission | 10 | 12-19-2013 03:02 PM |
| Dyno numbers list from Evasive Motorsports Meet/Dyno | Fish | Southern California | 29 | 02-24-2013 04:16 AM |
| Cheap Dyno? Sponsored Dyno? | swift996 | Mid-Atlantic | 3 | 02-09-2013 01:29 PM |
| Dyno Compilation - dyno testing results and recommendations | Illusive | Engine, Exhaust, Transmission | 82 | 02-08-2013 08:00 PM |
| Base line dyno figure (dynapak Hub dyno) | gtauto | AUSTRALIA | 16 | 10-08-2012 09:06 AM |
